3020 jd diesel in oil
   / 3020 jd diesel in oil #11
If this is a old 3020 diesel you have a fuel pump on the right side, front of engine it has a weep hole in it you shood see some dirty oil by the pump. sometimes the weep hole gets plugged with dirt and if the pump goes bad it will put fuel in crankcase.
The fix is a new fuel pump.
Could be fuel injection pump, But I would replace the fuel pump first.
Always check oil before start up
Good luck treetrimmer01
   / 3020 jd diesel in oil #12
I sure wish JD engineers hadn't numbered some of the CUT's using the same numbers as older JD tractors. It makes it very confusing.
   / 3020 jd diesel in oil #13
Turn pump upside down and after replacing u-cup seals(parts key #18) on drive shaft,lubricate the seals then carefully slide the shaft into pump(being careful to line up dots) so as to not wrinkle the first cup back. The JD tractors that are very difficult to install inj pump without a tool are the models that the shaft stays in the engine
Thank you for this information, I'm sure many of the members will appreciate it.
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
2017 FREIGHTLINER M2 106 (A53843)
2017 FREIGHTLINER...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
2006 Toyota Tundra 4X4 Pickup Truck (A53422)
2006 Toyota Tundra...
2025 Platform Safety Basket Attachment (A53421)
2025 Platform...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
