3020 jd diesel in oil
   / 3020 jd diesel in oil #11
If this is a old 3020 diesel you have a fuel pump on the right side, front of engine it has a weep hole in it you shood see some dirty oil by the pump. sometimes the weep hole gets plugged with dirt and if the pump goes bad it will put fuel in crankcase.
The fix is a new fuel pump.
Could be fuel injection pump, But I would replace the fuel pump first.
Always check oil before start up
Good luck treetrimmer01
   / 3020 jd diesel in oil #12
I sure wish JD engineers hadn't numbered some of the CUT's using the same numbers as older JD tractors. It makes it very confusing.
   / 3020 jd diesel in oil #13
Turn pump upside down and after replacing u-cup seals(parts key #18) on drive shaft,lubricate the seals then carefully slide the shaft into pump(being careful to line up dots) so as to not wrinkle the first cup back. The JD tractors that are very difficult to install inj pump without a tool are the models that the shaft stays in the engine
Thank you for this information, I'm sure many of the members will appreciate it.
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2020 Autocar ACX Xpeditor T/A Front Loader Garbage Truck (A55852)
2020 Autocar ACX...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A55851)
2025 Kivel 42in...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
