3040 stopped running
/ 3040 stopped running #1
burf3040
New Holland 3040
Hello to all. I am a new member and this is my first post. I was plowing snow tonight with my New Holland 3040 with just 200 hrs on the clock. Tractor was running fine and then it just lost power and slowly died. This same problem just happened at about 170 hrs. The battery was weak so I replaced it and everything was fine. The tractor cranks over with no issues. I put jumper cables on just in case. I had 1/4 tank of fuel. I put another 5 gallons in just to be sure it had enough. Has anyone had this issue?
/ 3040 stopped running #2
Have you changed the fuel filter? Or at least drain out any water in the sediment bowl? Sounds like fuel starvation.
Welcome to TBN!
Dave.
Hi Dave.Yes I changed the filter at 70 hrs. The bowl and filter look very clean and no sediment. If water is in the bowl would you see a line or differance in color? Thank You for responding.
/ 3040 stopped running #4
You might while the bowl is still new. It sounds so much like your engine is lacking fuel, it wouldn't hurt to remove the filter bowl and dump it, then open the fuel valve and let some drain into a tin can before putting the filter back on. You would be fairly certain then that you aren't fighting water.
You may have to purge the air from your fuel line after reassembly. Your manual probably shows the procedure for that, it is simple really.
Dave.
Dave, I will try dumping the bowl Thank You. Do you know what the fuel shutoff relay is for.
/ 3040 stopped running #6
I have a fuzzy idea but would rather let someone who really knows answer you.
You might want to include more info on your 3040 model, that helps people help you.
Dave.
/ 3040 stopped running #7
Since this is occurinng while you are plowing snow, I'd guess you have a clogged filter maybe due to water in the fuel. This is a common cause of run downs during cold weather. You haven't changed the fuel filter in 130 hrs of operation and that's over how long a time period? It's a good idea to change your fuel filters in the falll before the cold weather. Drain the sediment bowl or water separator before every use in the winter and after very use and try to keep your tank full to prevent condensate from putting water in your tank.
You could also have water in the tank freezing on the strainer at the fuel tap.
You were right. Took the bowl off, no fuel. I filled the bowl with fuel and got it running but it did't last long. When I put the fuel in the tank tonight I almost could not turn the fuel cap. Do you think this could be indicating a venting problem? Does the cap have a vent in it? Not sure where to start my troubleshooting. Dave thanks again, big relief to move the tractor away from the road and get it close to the house. Nh 3040,shuttle shift,Fel,backhoe,forks
Jerry/mt Thank You for your reply. Where is the fuel tap? How can I prevent the issue you speak of.
Sorry Jerry/mt, this is my first time posting and I did not see your full reply for some reason.
/ 3040 stopped running #11
If there is freezing or trash around the screen, you have to remove the tap to clean it.Its' at the bottom of the tank and feeds the line to the water separator. If you don't have a drain plug in the tank , siphon the fuel out of the tank to minimize spilling it all over and then remove the tap and clean the strainer. While you've gone this far, check and make sure that you don't have a bunch of crud in the tank. Put it back together and refill it and put some fuel additive in . Power Service White will help disperse water, help prevent gelling in really cold temperatures, and up the cetane number a bit to help starting. Keeping the tank full after working the tractor will minimize condensation to help keep water out.
I believe your cap may be vented but the vent can get frozen during cold weather so remove the cap, see if the venting is plugged with dirt or ice and see if that helps improves fuel delivery to the water separator. Clean, water- free fuel is essential to winter operation of diesel engine and you have to do everything to keep water, algae, and dirt out of the fuel in order to avoid these problems. Does your fuel filter have a drain on it. If so, drain some fuel out of that after you get fuel to flow to your water separatorand consider replacing the fuel filter because winter's not over yet. It's a good idea to have an extra fuel filter on the shelf just in case.
Good Luck.
Took the day off from work to see if I can get this thing fixed. It was about 20 Deg f last night . I think I will spend some time and try to get it inside before I take the tank off.
/ 3040 stopped running #13
Glad you were able to get it away from the road - that's where tractors always break, or a half mile back in the woods :D
Sounds like you know fuel is the problem now and Jerry covered the bases there I think. Just guessing, ice/water is probably your issue since your tractor isn't very old. Thawing it out is a good step, since ice doesn't run :)
Like Jerry said, you have to keep after water accumulation. Drain/dump your filter bowl more frequently, use a water dispersant diesel additive, keep your tank full as much as possible, and monitor your fuel quality a bit.
Dave.
/ 3040 stopped running #14
Do you need to take the tank off to to drain it? Can't you siphon the fuel out?
/ 3040 stopped running #15
I just looked at your fuel schematic on the NH parts page and it appears you can check for flow from the tank by removing the tank to filter line at the filter. It appears you do not have a fuel tap at the tank, just a 5/16" barbed hose fitting. Before you go taking the tank out, see if you have fuel coming out of the fuel delivery line to the filter. Capture the fuel in a glass jar and let it sit for awhile and look for water in the fuel. Water will settle in the bottom of the jar. If it's flowing (continuous and filling the fuel line) I would not remove the tank but I would try to drain all the contaninated fuel out and let any water or sediment, etc settle out. You can decant the good fuel on top off, filter it through a clean cloth and reuse it.
/ 3040 stopped running #16
Here is a good thread to read about fuel feed problems. Note that my first comments about the fuel pump being before the fuel filter are not correct. The fuel pump is after the filter even though the NH Repair manual shows it is before it. Not only do you want to make sure your fuel supply line is clear, but also your fuel return line.
If you are thinking your fuel cap might be the problem, just try starting and running the tractor with it loose to see if it is actually a cap venting problem. You can also use reverse pressure on the fuel supply line to the filter to blow back any trash that might be in the line. To my knowledge, our fuel tanks don't have any screen in the bottom where the fuel exits.
It sounds to me like you are getting some good advice so far and you're on the track to finding the problem. I bet you'll find a slug of ice somewhere in the fuel line, but it might just be an iced up fuel cap that needs to be defrosted. That could cause a vacuum on the tank and keep fuel from flowing.
Yes good advice from everyone,thanks to all who replied. I got a little lazy and did not want to take the tank off so I sent some air into the line that went to the tank. Something was in the line because fuel started to flow. Filled the bowl and let it sit. Went and got some Diesel 911 and added to the tank. I ran the tractor for over an hour with no issus today.I was a little suprised that the fuel bowl looks the same with fuel in it or not. That was half the problem. Lesson learned.
/ 3040 stopped running #18
Good news. Glad you have it under control and back to working. :thumbsup:
Dave.
/ 3040 stopped running #19
Glad you got it running. What did the fuel that came out look like?
The fuel looked fine. When I filled the bowl for the first time I let it sit for about 1/2 hour while I went to the store.When I got back the bowl looked even in color. The first time I took the bowl off and found no fuel in it I did find a few globs of brown slimmey matter at the bottom of the bowl. I fill the tractor with the same 5 gal can and only use diesel from the filling station.
