30B PTO shifting problem
/ 30B PTO shifting problem #1
oldcowboy
Declo ID
mf 185 case 1630
Hi, New here.. Working on a 30B with loader. Its a new Tractor to me... It has new clutch, but now the PTO grinds in with no load and almost will not go in with a load. Engine off will shift in but wont start if there is load on the PTO. with a load you have to jerk it in but that cant be good on things.
Any one know where to begin?
/ 30B PTO shifting problem #2
:welcome:
To the forum from Alabama.
/ 30B PTO shifting problem #3
Not sure what a 30B is but is yours a two-stage clutch? Does it slip into gear (drive) with no grinding? Sure sounds like the PTO is not disengaged (but you knew that). Could the new disc be out of adjustment? What have you tried?
Jim
/ 30B PTO shifting problem #4
I have the sister to your tractor a 20C but yours has inboard brakes in the rear. The tractor has a two stage clutch. The symptoms your describing indicate that the clutch is going out or it is out of adjustment. The engine will not start because the pto clutch is not entirely disengaging causing a drag on the engine.
I would first see if it is out of adjustment. Under the tractor there is an inspection cover for the PTO. Pull it off and adjust the bolts to .090" as shown in this photo.
http://vintagetractorengineer.com/wp-content/uploads/2009/01/adjusting-pto-clutch.jpg
If that does not work then you will need the clutch replaced. I hope you do not have a loader on your tractor.
2010 GMC W5500 HD 16FT Box Truck (A61573)
2010 GMC W5500 HD...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
APPROX (80) PIECES OF 48" X 56" EXPANDED METAL (A64280)
APPROX (80) PIECES...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
1993 International 4900 Utility Flatbed Truck (A64194)
1993 International...
UNUSED (16) PIECE 2M RATCHET STRAP SET (A64280)
UNUSED (16) PIECE...
