32-1, 40-1, 50-1 what the heck is wrong here?
   / 32-1, 40-1, 50-1 what the heck is wrong here? #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
Why can't these stupid manufacturers get their heads together and make these oil/gas mixture devices all the same. How many of you have a Homelite anything with 32-1 and a Husky whatever with a 50-1 or a Poulan whatever with the 40-1 ratio? I do not want to mix different gas for each power tool. So what would you do? Find a happy medium like 40-1 and run them all on it? Why can't all of them run on a 50-1 mixture? Is it poor quality of parts that require a higher degree of oil mixture? So tell me, what do you guys do?
   / 32-1, 40-1, 50-1 what the heck is wrong here? #2
Right, wrong or indifferent, I run all my two cycle stuff using John Deere exact mix. I put one of those little four oz. jugs in a gallon of gas and use it in everything. Have been doing that for four years and have had no adverse affects on any of my engines. I am running two JD weed eaters, an Echo weed eater, Echo blower, JD chain saw and a Homelite chain saw. /forums/images/graemlins/smirk.gif I was getting tired of having to label all the cans and trip over them when going into the lawn mower shed.
   / 32-1, 40-1, 50-1 what the heck is wrong here? #3
I'm stubborn I guess. I have four different cans in the shed, all with different mixes. If I run out of one I will use the next oilier(sp?) mix if I'm in a hurry. I have read that all of the engines will run alright on a modern 50:1, but I can't afford to find out if they're right. I have one big & old Poulan, one of the real ones, that uses 16:1 (8 oz. of oil to gallon, is that ratio right?) I just can't see it running on 50:1.
   / 32-1, 40-1, 50-1 what the heck is wrong here? #4
I have three Stihl chainsaw all recommending 40:1 mix, I have always mixed at 32:1 and have never had a problem with hard starting or smoking. I'd use the heavier mix if it were me.
   / 32-1, 40-1, 50-1 what the heck is wrong here? #5
If you only want to use one mixture for all your engines, use the 32:1 mixture ... a bit more oil in the other engines shouldn't hurt it like but too much gasoline in the mixture would.
   / 32-1, 40-1, 50-1 what the heck is wrong here? #6
Same here...JD chainsaw, Sthil chainsaw, 2 JD weed eaters, Poulan leaf blower and probably something else I am forgetting. /forums/images/graemlins/smile.gif
   / 32-1, 40-1, 50-1 what the heck is wrong here? #7
Jim,
When I ran my Poulan saw I kept 2 seperate containers for my 2 cycle stuff. Now I make sure I buy eqiupment that all uses the same ratio and I am down to one container.
I have heard you can use the 32:1 mix for everything but I always assumed that would lead to fouling of the plugs.
Phil
   / 32-1, 40-1, 50-1 what the heck is wrong here? #8
I use Stihl low-e oil 50-1 in all mixed fuel equipment.
   / 32-1, 40-1, 50-1 what the heck is wrong here? #9
I keep (2) 1 gallon cans.
1 at 32:1 for everything Homelite
1 at 50:1 for everything Husqvarna
For the 40:1, I fill the tank 1/2 way with 32:1 the other 1/2 at 50:1.
I wouldn't trust my Homelites to last very long if running at 50:1
My Husky's run perfectly at 50:1 so I don't want to increase the oil mix by almost 40%.
   / 32-1, 40-1, 50-1 what the heck is wrong here? #10
My Dealer once told me that it doesn't matter what you run as long as you are consistent, and you run FRESH Hi-test fuel. He said changing the mix or even the oil brand was worse than using more or less than recommended. In his shop he mixes 50:1 for everything using a premium oil.
If I recall correctly my Husky Saw and my JD Weedeater both say 50:1 if using Husky / JD oil, but 40:1/32:1 if using someone elses oil. Personally I mix 1 can of Hi-test 32:1 and use it in everything.
(Side topic - don't try to fill a 1 gallon can with Hi-test from a multi-grade pump. You'll get whatever the previous guy used and pay for premium - and the next guy gets a bonus in the lines. I make a special trip for hi-test to the one station with a dedicated pump.)
2019 Ford F-150 Pickup Truck, VIN # 1FTFW1E46KKD75859 (A44391)
2019 Ford F-150...
2006 Ford F-450 XL Super Duty (A44501)
2006 Ford F-450 XL...
Kivel 48in Forks and Frame Skid Steer Attachment (A44571)
Kivel 48in Forks...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A43004)
2018 FREIGHTLINER...
2018 Kubota L4060 Tractor (A44391)
2018 Kubota L4060...
E-Z Trail 3400 Gravity Wagon with Honda EX27 9HP Gas Engine (A46877)
E-Z Trail 3400...
