3520 losing curl pressure on FEL
   / 3520 losing curl pressure on FEL #11
Show a pic of your loader valve.
If you can find the IN port of the loader valve , it will be close to it.
Look for hex nut on top of valve.
   / 3520 losing curl pressure on FEL #12
What is the relief valve?
Kinda hard to get to without taking some stuff loose, but if you try hard you can get to the adjustment from the top by just taking a few bolts loose so you can shift some of the plastics. You need to have a gauge to do it right.
And as always, I recommend buying the technical manual. One of the best reads ever.
2018 MACK CHU613 DAYCAB (A58214)
2018 MACK CHU613...
10 - 3/16in Plate Steel Sheets (A55973)
10 - 3/16in Plate...
LOT: (2) Bucket Hand Pumps: (1) Gear Oil 1/2 Full, (1) Tranny Fluid 1/4 Full (A59076)
LOT: (2) Bucket...
JOHN DEERE 5 BOTTOM PLOW (A52708)
JOHN DEERE 5...
2015 MACK CXU CONVERTED TANDEM AXLE DUMP TRUCK (A58017)
2015 MACK CXU...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
