3525 3pt hitch loose bolts
   / 3525 3pt hitch loose bolts
he replaced the factory bolts with a nylon lock nut and a lock washer...same problem. I think the problem won't be resolved until he directs the exhaust away from the bolts or goes with the cotter pin method.
   / 3525 3pt hitch loose bolts #12
fiberlocks are no good in heat. i like the idea of a better grade of bolts and an impact gun.
   / 3525 3pt hitch loose bolts #13
You can also double nut it. That is after you get it tight put another nut on there and that will act as a jam nut. If that don't work you can do the extreme and tack weld it. /forums/images/graemlins/smile.gif
Tony
2008 AAR MOBILITY SYSTEM REFRIGERATED BOX (A52576)
2008 AAR MOBILITY...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
LMC G500-500A LOT NUMBER 232 (A53084)
LMC G500-500A LOT...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2022 KMC 5610 LOT NUMBER 212 (A53084)
2022 KMC 5610 LOT...
2020 HYUNDAI TRANSLEAD 53X102 REEFER TRAILER (A52576)
2020 HYUNDAI...
