3525 3pt hitch loose bolts
   / 3525 3pt hitch loose bolts
he replaced the factory bolts with a nylon lock nut and a lock washer...same problem. I think the problem won't be resolved until he directs the exhaust away from the bolts or goes with the cotter pin method.
   / 3525 3pt hitch loose bolts #12
fiberlocks are no good in heat. i like the idea of a better grade of bolts and an impact gun.
   / 3525 3pt hitch loose bolts #13
You can also double nut it. That is after you get it tight put another nut on there and that will act as a jam nut. If that don't work you can do the extreme and tack weld it. /forums/images/graemlins/smile.gif
Tony
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
1982 MACK RD685S HOTOILER (A52472)
1982 MACK RD685S...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
3 Point Metal 4ft Cargo Carry (A51573)
3 Point Metal 4ft...
City of Buckhannon - 2000 Chevy 2500 (A52384)
City of Buckhannon...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
