3525 3pt hitch loose bolts
   / 3525 3pt hitch loose bolts
he replaced the factory bolts with a nylon lock nut and a lock washer...same problem. I think the problem won't be resolved until he directs the exhaust away from the bolts or goes with the cotter pin method.
   / 3525 3pt hitch loose bolts #12
fiberlocks are no good in heat. i like the idea of a better grade of bolts and an impact gun.
   / 3525 3pt hitch loose bolts #13
You can also double nut it. That is after you get it tight put another nut on there and that will act as a jam nut. If that don't work you can do the extreme and tack weld it. /forums/images/graemlins/smile.gif
Tony
2016 GMC Sierra Pickup Truck, VIN # 1GTN1LEC5GZ901362 (A51572)
2016 GMC Sierra...
Duetz Power Unit (A50120)
Duetz Power Unit...
40ft High Cube Shipping Container (A51573)
40ft High Cube...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2008 Sterling Bullet Utility Truck, VIN # 3F6WK76A88G352277 (A51572)
2008 Sterling...
