3720 cab vs open air
   / 3720 cab vs open air #51
Steve,
I understand your position and your purchase of the cab. I can even understand if somoeone can afford something and it isn't a live or die item. Heck, I could have stayed with my 2720 if that was the case!
Rob
   / 3720 cab vs open air #52
Rob, there was a weird "double flitch beam" made up for that attached garage. The outside walls were 6" walls, and the beam had two steel plates in it and wood bolted all around. There was a structural engineer involved in the design of the house at various places, and this was one of them. Floor trusses also rested on these beams. Architect error messed up this area too, but that's a different off post story.
So the delta cost was about $200 per door, and maybee $100 for the fancy beam. A lot of $$s for an extra 3". The apron going up to the garage is sloped down. So that extra 3" means it all just works, and things that are designed to clear an 8' opening really do (things like a cabbed JD CUT tractor :thumbsup:). I've seen a lot of places get in trouble when the opening is 8' and then it comes in a bit for the trim and weather seal. The clearance of our bay doors at the fire department is 9' 10.5" due to this sort of problem.
Reference Steve's post, the two doors on my outbuilding garage are 10' x 10' and 8.5' x 12'. So all tractors can park using either door. But everything stays on the property. If I was trailering stuff around, I agree that 14' high doors would be a must. I also like parking everything indoors so it keeps well and I don't have to fight the wasps that would otherwise call an implement "home" :laughing:.
Pete
   / 3720 cab vs open air #53
Pete,
Interesting, never heard of that beam.
My tractors just clear the ~8' door which is slightly below the header when fully opened. I got a rude awakening one winter morning when I went out and hit the door because ice had built up on the apron!
Rob
I must say thanks for all the great thoughts. I plan on driving a 3720 with a cab next week. I want the R4 tires so now I need to determine if the larger tires are better for the 3720. According to the numbers, they only add a few inches and will still fit in a 8' garage door. I assume they are wider which should help increase the stability, unless the smaller tires provide the best stability putting the CG lower. WOW. I bought my last truck with less thought.:D
   / 3720 cab vs open air #55
You're doing the right thing thinking it out and asking lots of questions. Wish i had asked as many on my first tractor, this time I asked until no one wanted to talk to me anymore!... But I'm getting a great tractor with great options!
Rob
   / 3720 cab vs open air #56
I think the larger R4 tire is 2" taller which will gain about 1" of overall height. I am not sure if the larger R4 tire is any wider in the overall width. If it is wider, it is not by much. Overall, the larger R4 tire isn't not going to change the CG very much. Loaded tires or wheel weights are your overall best choice. Custom made spacers are expensive.
   / 3720 cab vs open air #57
Spudland, they (clopay) makes a 8' 6" door that just a bit more than the standard 8' door.
Thanks Pete, thats EXACTLY what I want. As luck would have it...my current garage already has a clopay in it, so by default (SWMBO) the new garage was to have Clopay's as well! With a new baby due within 3 weeks...garage door shopping hasnt been high on my list of priorities.. :laughing:
Rob-D said:
I do try to justify my purchases, it really bothers me to buy something I really don't need, just me!
Well, seriously speaking...when getting down to pencil & paper, do many of us need what we have for tractors? Seriously...do I need a F935 and a 3520 Cab to take care of my property? We own a hair over 2 acres and less then 1/3 of it is cleared... On pencil & paper I'd prolly be hard pressed to justify a single 2320 with MMM, etc...
jenkinsph said:
Dave,
I would really recomend a 10' door height as a minimum. While asthetic reasons are good, "form follows function" is the winner here. My next building will be a parking garage with 14' sidewalls with 12' high sidewall doors. Might see if I can install a 14' high door on the gable end too. Much easier to store my backhoe on its trailer in the garage with high doors, much more asthetically pleasing to have the yellow backhoe inside rather than in the yard.
I know what you mean...I live in what I'll call "nice" neighborhood (remember 2 acre lot)...so I dont want to be the guy that has a HUGE shop and a tiny house. I'm going to extreme measures to make the garage appear as small as possible... I Could care less about the neighbors though, SWMBO is what I care about. 2 years ago we built a 12x16 garden shed for all of SWMBO's gardening tools...What I had envisioned and had quoted for materials was gonna cost me 1,300 to build. When SWMBO was done with her changes the grand total was just a hair under 2,500 bucks... When you have to custom order shutters that exactly match the house, it starts adding up quickly, LOL...
   / 3720 cab vs open air #58
Dave,
I only have about 16 acres but Dawn has horses down the road and that's a couple hundred but they are fenced and don't use it all. The 2720 was a little small for me when it came to using the loader or the BH. That's why I'm going to the 3320.
I probably would have stayed with the 2720 but Dawn got the 990 and the power in the loader was immediately evident when I was clearing about an acre of scraggly Thorn trees. She has the 73" HD bucket with the tooth bar which is also night and day.
I agree about the garage. What I did when I built my house was plan on using the attached garage as a work shop and building a new three car for welders and tractors, etc. I didn't want the garage to look like it was the main house so I set it back when I built it a couple of years ago even though my neighborhood is dairy farms.
When the new tractor comes in I'll have to take some pictures of the place as it's starting to look pretty good now. (something I couldn't have done without the tractors!)
I like the size of the 3x20 tractors, I get more power in the loader than the bigger 990 in a smaller size so going to a 4x20 series isn't in my future, although I better keep my mouth shut!
Rob
   / 3720 cab vs open air #59
Rob and others,
While there are all sizes of tractors for the diferent uses people have I have found there to be very little difference in footprint for the compacts. I can understand wanting a tractor that will fit in an existing garage/shop or small lot and acreage. In my experiences there is a big diference in the abilities between a 2X20 and a 4X20 tractor while the difference in width and length is not that great. Not saying that a 4x20 will fit everywhere you can put a 2x20 machine but in my experiences with landscaping various sites it is amazing how tight a place the larger tractors will fit in.
   / 3720 cab vs open air #60
Rob and others,
steve,
I just checked the size specs on the 2x20, 3x20 and 4x20 tractors.
OK, the wheel width between the 2 and 4 series is:
52.6" 2527,2727 ;51" 2320
90" 4xxx
That's over 3 feet difference and a lot in my opinion.
The length is 128.2" 4xxxx
108.9" 2520,2720
Height, top of ROPS (ROPS not folded)
4xxxx 97.2"
2x20 89.7"
The 4x20's won't fit under my 8' door so they are out of the running
for me.
These differences don't look at the 2305 which is much smaller than the 4x20 series.
I've used Dawn's 990 (4005) and it is much larger than the 2720, the tires are 48" as opposed to, I think, 35" for the 2520, 2720, the 2320 is even smaller andthe 2305 much smaller, I think about 24 or so inches, that's half the size of the 4xxx tractors. That's a lot more tire.
The difference in weight is 2520 = 1600 or 1700 lbs. and the 4x20 = 3700 lbs., that's a ton more. Put them all side by side and you'll see the marked difference. It's a lot.
Rob
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
STS MUD MIXING MACHINE (A50854)
STS MUD MIXING...
2018 RoGator 1100C (A51039)
2018 RoGator 1100C...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2004 INTERNATIONAL 4300 CARGO TRUCK (A50854)
2004 INTERNATIONAL...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A51039)
Morooka MST 660VD...
