3840 Coolant Temp Sensor
/ 3840 Coolant Temp Sensor #1
hlpdobro
Frederick Co MD
Montana 3840
Not getting a reading on the temp gauge and havn't located the coolant temp sensor (or whatever Montana/Mitsu calls it). Would someone kindly point me towards the sensor location?
Thanks in advance.
hp
/ 3840 Coolant Temp Sensor #2
purely from memory I'm going to say top front of the engine close to the thermostat. A couple years ago I was having heating problems on my 3040 and when I pulled the thermostat to test it I remember seeing the sensor close and thinking that also could be my problem. I'm not near the tractor so I can't go look, sorry. My guess would be corrosion where the wire connects to the sensor.
gary
/ 3840 Coolant Temp Sensor #3
It's right under the thermostat - front of the engine, where the top radiator hose connects.
I've got the same issue on my 3840 - checking the sensor directly, the resistance changes as the water heats, hits a stable level (around 550 ohms) once the engine is warm, then goes up and down as the thermostat opens and closes.
Temperature gauge never moves. Tomorrow, I'll be popping the dash open and trying get to the root cause.
1987 Fruehauf MC 307 Insulated 7,500 Gallon T/A Chemical Tanker Trailer (A64194)
1987 Fruehauf MC...
2017 Ford Escape SUV (A64557)
2017 Ford Escape...
2002 FORD UTILIMASTER 4X2 S/A STEP VAN (A67148)
2002 FORD...
2025 KUBOTA KX033-4 EXCAVATOR (A65053)
2025 KUBOTA...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
