clemsonfor
Super Member
i didn't know HF had a kit.. should shopepd around.
I had another idea as well.
when ;ooking, I saw two types of kits.
1 type was just a clear 'coating' you applied with a sponge tip applicatior.., the other was the sand and buff type.
i wonder if you did the sand and buff, thensealed it with the other type if it would last longer?
happy right now.. my two trucks have clear lamps not frosted...
soudnguy
The HF kit like i said had a 1000+ grit sanding disk for the drill. Thats got to be bettter than the rubbing by hand grit or any mirical polish that you see at the stores in my mind as your basically resurfacing the plastic to a shine.
Like i said HF has at least 2 kits . The one i got made by CCP and one by 3m and maybe another one, just not sure? The one i got looks cheap and i just got it cause it was only $6 or $9. I tried it on my old ranger before i put i to the the new highlander cause i did not want to ruin anything. It worked so well i bought it again to use on the TOY. I have seen at the parts places as well ad walmart some of the polishes that you use by hand and ther is no way that they can work near as well as the drill powed sanding ones like i got or sounds like you got!
