3PH updated...
/ 3PH updated... #1
Dadsgreenpsd
Bronze Member
Maine
Jinma 254, and JCB 1550B
Well, the hitch works, although it is still stiff. I have had it apart, there seems to be nothing in the bore, or on the spool, but it just doesn't slide good. Hopefully, it will either smooth out, or I will get another valve. Other than that, I have had all of the attachments on, have learned that an old stump can be pulled up by the bush-hog, and will wedge itself into the blades very tightly, and everything seems to work pretty good. Now, onto the regular maintainence... My next step is to change the rest of the fluids, so I am off on a search for an engine oil filter. I am sure that has been discussed before. ;) Thanks to all who responded, Great group here!
TANK MANIFOLD (A58214)
2012 CM TRAILER (A60736)
2012 CM TRAILER...
1991 INGERSOLL RAND DD-24 SMOOTH DBL DRUM ROLLER (A62129)
1991 INGERSOLL...
2016 PETERBILT 579 (A60736)
2016 PETERBILT 579...
2014 Freightliner 105' Bucket Truck (A61307)
2014 Freightliner...
FUEL PUMP W/ NOZZLE (A60736)
FUEL PUMP W/...
