3PH Woods RM42 Mower
   / 3PH Woods RM42 Mower #1
CamshaftLF
Central Pa.
96 KUBOTA L2350
Hi everyone: I am asking this question for a friend, He purchased the RM42 for on his BX2100 he didn't put up much $ for it. But its made to run CCW is there a way to change it to CW.
Thanks for any input.
   / 3PH Woods RM42 Mower #2
Hang on to it and put it up for sale. There are a few people out there with the Satoh CCW PTO that are looking for one like you have . Buy the correct one and you'll make 2 people happy.
   / 3PH Woods RM42 Mower #3
You can purchase the proper rotation blades for it from any Woods dealer. If he does not want to replace the spindles, just make sure he uses locktite on the bolts. He should be fine.
Gary
   / 3PH Woods RM42 Mower #4
Tell your friend Iam in the market for this type of mower, also live in central pa. contact me by e mail mirum52@dishmail.net with phone #
   / 3PH Woods RM42 Mower #5
Does he have the manual? I just got a Woods RM42 on a used mower and I need to know the proper RPM. I致e seen numbers, online, from 540 to 2000. I like to get a manual as well as find out about the proper speed.
   / 3PH Woods RM42 Mower #6
I had on old RM42 and have attached 3 .pdf's of operator's manuals in a .zip file. I don't know what the difference is between the files but perhaps they will help. I had to use a .zip because 2 of the files are over the 1 MB limit for .pdf files.
One of the manual files is under 1 MB so I can attach that as a .pdf if the .zip does not meet your needs.
   / 3PH Woods RM42 Mower #7
If you go to the Woods Equipment web site and look for manuals, they have all of the manuals online for download for free. I got mine for my RM48 there last week.
Woods Equipment Company - Manuals
The only difference between the CW and CCW models is the spindle shaft (left hand vs right hand thread bolts) and the blade. Other than that it's all the same. Cost of a new spindle will be expensive however.
   / 3PH Woods RM42 Mower #8
Thanks. That sound like what I need but I can't get it to extract. I've tried doiwnloading it a couple of times and get "End-of-central-directory signature not found. Either this file is not a Zip file, or it constitutes one disk of a multi-part Zip file.".
   / 3PH Woods RM42 Mower #9
Thanks. I found it. I couldn't find just a RM42 but the manual I found will work.
UNUSED (1) 5200# DROP AXLE W/ BRAKES (A54756)
UNUSED (1) 5200#...
2001 MACK CH613 DAY CAB (A54313)
2001 MACK CH613...
UNUSED LANDHONOR 5/16" 7' G80 DBL CHAIN SLINGS (A54757)
UNUSED LANDHONOR...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
(2) GAS HEATERS (A54757)
(2) GAS HEATERS...
2007 Ford Five Hundred (A55758)
2007 Ford Five...
