3pt "expansion" pins?
   / 3pt "expansion" pins?
Re: 3pt \"expansion\" pins?
Yup, those would be the type. Can't see an easy way to order 4-5 though. Have you ordered from them before?
Regards,
Dave
CTyler, thanks for providing those links. They gave me the right "words" to find them on the internet. If anyone wants them they appear to be available at http://www.mcmaster.com
Thanks again guys, you just saved me and my fat fingers some time when hooking up implements! /forums/images/graemlins/smile.gif
Have a good one,
Dave
   / 3pt "expansion" pins? #14
I had the same problem with these pins. Started using a larger hairpin clip.
<font color="blue"> I bought 3/8 inch "ball spring loaded pins </font>
A 3/8” pin will work. But the original is a 10 mm (.394”).
I bought a spare set after I lost the set that came with tractor. /forums/images/graemlins/tongue.gif I did find them. /forums/images/graemlins/smile.gif
It took a week to get the spare set. They are not a dealer stocked item. /forums/images/graemlins/wink.gif
I have attached a picture showing the larger hairpin that I use.
   / 3pt "expansion" pins? #15
That's strange that they don't use a 12mm like the larger ones use. /forums/images/graemlins/ooo.gif You would think that they would use the same size, no more different in size than they are. It would cut down on inventory. The 12 mm ones have a handle and a chain on them.
   / 3pt "expansion" pins? #16
dmftoy1, I found mine at a True value, but think if you went to any hardware store and started looking at clevis pins, you'd be in the right spot in the store.
Someone else pointed out here that I should have 10mm, which is likely true, but with a slop fit in the holes, I don't notice my implements moving around.
The second link that CTyler posted looks like what I bought, minus the safety wire.
Best wishes,
Ron
   / 3pt "expansion" pins? #17
I replace all my kotter pins that were frequently removed with hairpins, if necessary I drill out the holes so the hairpins would fit. This works okay, I do like the Detent Clevis Pins idea; however, I've had one of these to "freeze" on me before.
BTW the technical term that I have always called the telescopic stablizer control links were "check chains".
Rover
   / 3pt "expansion" pins? #18
</font><font color="blue" class="small">( Yup, those would be the type. Can't see an easy way to order 4-5 though. Have you ordered from them before?
)</font>
Hi, I've never order from them. Just went searching for lynchpins and they had pics. Pics are good...I like pics /forums/images/graemlins/grin.gif
   / 3pt "expansion" pins? #19
Dave
Could you please post a page number or part number... with over 400,000 items, I don't think I have enough years left to sort it out....... LOL..... OK.... I tried to find them and I couldn't and now I am being lazy and asking..... Junkman
I did a search on "detent pins" and then clicked on the "pins" link. The one's I ordered were the cheap ones, but they had some really nice one's with handles, button releases, etc. The part# for what I ordered is: 98320 A373
Regards,
Dave
2010 PETERBILT 367 HOT OIL UNIT (A53843)
2010 PETERBILT 367...
205113 (A52706)
205113 (A52706)
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
We do NOT accept credit cards as payment. (A50123)
We do NOT accept...
JOHN DEERE 444-624 - 60" LOADER FORKS (A52705)
JOHN DEERE 444-624...
SAKAI SV544 SMOOTH DRUM ROLLER (A52706)
SAKAI SV544 SMOOTH...
