3pt hitch adjustable side link bent
   / 3pt hitch adjustable side link bent #1
jedens
Bronze Member
La Veta, CO
Kubota 4610
My adjustable side link got bent when I acidentially raised my 3pt hitch while my backhoe (frame mounted) was mounted over it. I've got a Kubota L4610 and the side link has a crank handle on it. Do I have to order one from kubota or does someone make an aftermarket one (hopefully one that is stronger than the stock one).
   / 3pt hitch adjustable side link bent #2
The only aftermarket lift links I know of are engineered for specific older mass produced tractors. Perhaps one would spec out similar to yours. I wouldn't look for one much stronger, something more expensive than a lift link may be vulnerable then. NH applications disable the hitch when the hoe is installed, a good safety feature.
   / 3pt hitch adjustable side link bent #4
if you post a pic we may be able to recomend a fix or suitable replacement, it might be something fixable by bending it back, or im thinking possibly one of the aftermarket ford tractor ones may be able to be modified to fit with bushing etc
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A43004)
2019 FREIGHTLINER...
2018 Ram 2500 Pickup Truck, VIN # 3C6TR5HT2JG344853 (A44391)
2018 Ram 2500...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A44572)
2017 Ford F-150...
2011 MAGNUM PRODUCTS LIGHT TOWER/WATER TANK TRAILER (A45046)
2011 MAGNUM...
2004 Rosco Challenger 2 Ride-On Rotating Sweeper (A44571)
2004 Rosco...
Graco SmartControl 2.0 Digital Airless Line Striper (A44571)
Graco SmartControl...
