3pt hitch adjustable side link bent
   / 3pt hitch adjustable side link bent #1
jedens
La Veta, CO
Kubota 4610
My adjustable side link got bent when I acidentially raised my 3pt hitch while my backhoe (frame mounted) was mounted over it. I've got a Kubota L4610 and the side link has a crank handle on it. Do I have to order one from kubota or does someone make an aftermarket one (hopefully one that is stronger than the stock one).
   / 3pt hitch adjustable side link bent #2
The only aftermarket lift links I know of are engineered for specific older mass produced tractors. Perhaps one would spec out similar to yours. I wouldn't look for one much stronger, something more expensive than a lift link may be vulnerable then. NH applications disable the hitch when the hoe is installed, a good safety feature.
   / 3pt hitch adjustable side link bent #4
if you post a pic we may be able to recomend a fix or suitable replacement, it might be something fixable by bending it back, or im thinking possibly one of the aftermarket ford tractor ones may be able to be modified to fit with bushing etc
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
2022 CATERPILLAR 330 EXCAVATOR (A60429)
2022 CATERPILLAR...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
Blast Off Hot Pressure Washer Trailer (A59228)
Blast Off Hot...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
