3pt hitch adjustable side link bent
   / 3pt hitch adjustable side link bent #1
jedens
La Veta, CO
Kubota 4610
My adjustable side link got bent when I acidentially raised my 3pt hitch while my backhoe (frame mounted) was mounted over it. I've got a Kubota L4610 and the side link has a crank handle on it. Do I have to order one from kubota or does someone make an aftermarket one (hopefully one that is stronger than the stock one).
   / 3pt hitch adjustable side link bent #2
The only aftermarket lift links I know of are engineered for specific older mass produced tractors. Perhaps one would spec out similar to yours. I wouldn't look for one much stronger, something more expensive than a lift link may be vulnerable then. NH applications disable the hitch when the hoe is installed, a good safety feature.
   / 3pt hitch adjustable side link bent #4
if you post a pic we may be able to recomend a fix or suitable replacement, it might be something fixable by bending it back, or im thinking possibly one of the aftermarket ford tractor ones may be able to be modified to fit with bushing etc
70in Dual Cylinder Grapple Bucket Skid Steer Attachment (A44571)
70in Dual Cylinder...
2022 Kingsport 248BH 26Ft. T/A Travel Trailer (A44572)
2022 Kingsport...
2014 Nissan Maxima Sedan (A44572)
2014 Nissan Maxima...
2015 Ford Explorer AWD SUV (A44572)
2015 Ford Explorer...
Swamp Buggy (A44391)
1999 International F-4900 Truck, VIN # 1HTSHADR8XH687128 (A44391)
1999 International...
