3pt hitch part on TC45D
   / 3pt hitch part on TC45D #21
</font><font color="blue" class="small">( Are you able to remove an implement if the turnbuckles are snug on your rig? )</font>
Yes.. since the turnbuckles are from the outside of the arm to the axle, when you pull the implement lift arm pin.. you are sliding the arm off, toward the chain/turnbuckle on that side.. and colapsing the chain.. so yes.. very easy... no sway adjustment or wrench needed to take an implement off.
Soundguy
   / 3pt hitch part on TC45D #22
</font><font color="blue" class="small">( Since Pat's System was mentioned earlier in this thread, I will give )</font>
How do those compair with the ford/NH flexlink system? I've got that on my 5000 and like it... gives each lift arm about 6" front to back play, and a few inches side to side/angle to hook up.. then backup to lock the arms in.
Soundguy
   / 3pt hitch part on TC45D #23
Soundguy )</font>
I liked the flex-link deal on my 7700, but both of them gave out - the little cable busted away. Things all look kinda traped together in there, not easy to fix......
My TW-20 has a better design, but hooking up cat 3 equipment just is never easy with pins - for example my 15 row bean planter, with the gauge wheels & 12" wide bean boxes on 15" spaces, there is no room for a person to get to the 3pt arms! Fortunately the cat3N standards are really a standard and most all things fit easily, so a quick hitch was certainly the way to go. Wow there must be stress on that top hook tho when my planter is full of beans & I hit a pot-hole....
I got some Pat's deals for my little 1720, but since I have been moving 5x6 round bales with it, have not installed them yet - takes every bit of power to lift the bales, can't afford moving the bale lift back 3 inches....
--->Paul
   / 3pt hitch part on TC45D #24
<font color="blue"> How do those compair with the ford/NH flexlink system? </font>
I am not familiar with the flexlink, but I see rambler has replied about that. He's also correct that Pat's system moves the lift point back a few inches, but that's not a problem for me.
The Deluxe Boomer hitch (without Pat's Easy Change) already provided the side to side and forward backward adjustability. For me, Pat's added the 'lift to lock' feature.
   / 3pt hitch part on TC45D #25
This isn't an awesome pic.. but it is the only one in my library with a good shot of the flexlinks on my 5000.
Soundguy
2008 PJ 32 FLATBED GOOSENECK (A58216)
2008 PJ 32 FLATBED...
2015 Freightliner M2 106 Altec 58Ft. Insulated Forestry Chipper Bucket Truck (A56858)
2015 Freightliner...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2022 Horizon (A55973)
PALLETS OF HEAVYEQUIPMENT (A58216)
PALLETS OF...
UNUSED WILD BOAR AR500 3/8" STEEL SHOOTING TARGET (A58376)
UNUSED WILD BOAR...
