3pt. hitch woodsplitter
   / 3pt. hitch woodsplitter #51
One thing to watch in all of this (my opinion) is to push with a flat and split on teh end so the wood keeps moving rearward and out of the way to load etc. Just keep inching the tractor fwd to extend the pile. I see a lot of splitters that have the wedge on the ram. That just looks like a mis engineered toe smasher and trip hazzard to me.
You work them differently. When large, you let the far large piece drop onto a catch platform and split small finished pieces off the large half still on the rail, throwing each to the pile. Its very nice not having the workpiece move.
larry
   / 3pt. hitch woodsplitter #52
larry
The MAIN reason to have the wedge on the ram instead of the beam is so you cah split vertically when you get the real big stuff.
Having a wedge on the beam and pushing with a flat plate would cause the wood to hit the ground and make the splitter lift into the air.
Almost EVERY splitter I have seen with the wedge on the ram is a horizontal AND vertical unit.
   / 3pt. hitch woodsplitter #53
Yeah, not having the workpiece move opens up lots of good possibilities. ... like convenience when the log gets stuck on the wedge.
larry
   / 3pt. hitch woodsplitter #56
Can you use a 4 way wedge on a moving wedge splitter?
A moving wedge would not be as well suited to it since forces are higher and reaction to the downward split parts would multiply stress. A fixed wedge assembly can more easily be designed with downward cutaways around the wedge on the rail to allow the wood to escape without interference. The slider platform mounting a moving wedge would have to be cut some to similarly relieve pinching and this would weaken it unacceptably in my estimation. A different rail design from a standard I Beam could be used to get by this issue.
larry
   / 3pt. hitch woodsplitter #57
That's why I like my setup. A 3pt pusher with simple drop on 4 way wedge. Pushed wood away from the tractor. I can catch the wood if necessary for a resplit and only need to shift back a little bit. Stuff that is sized I just let drop and nudge the tractor forward as the pile builds.
   / 3pt. hitch woodsplitter #58
LD1 says: "I am jsut stating the obvious facts that
1. on a 20-35HP tractor they ARE slower
2. They do consume more fuel
3. You are putting hours on a much more expensive machine"
He's right; you need a tractor that exceeds 35HP for full benefit of 3pt splitter; yes, they drink more; not too many hours in my case. I'm happy with the SplitFire; it's bi-directional, so the 14 sec run doesn't bother me. It's VERY well made; it's local, and it was delivered, free. Can't do better than that.
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A55302)
2016 KBH...
2011 Ford Crown Victoria Sedan (A55853)
2011 Ford Crown...
2015 Ford Fusion S Sedan (A54815)
2015 Ford Fusion S...
