3pt PTO log splitter.
   / 3pt PTO log splitter. #1
Bud Soda
Platinum Member
NC
Ford 5000, 3000
OK so I am going to pick up a powerhorse 3 point log splitter from Northern Tool. Instead of using my tractors rear hydraulics I want to use a pto driven pump. I plan on using a PTO pump by Prince with 21gpm flow. I will also use a 21 gallon tank and a filter.
I know the return (out from splitter) line will empty into the tank but do I install the filter in the return line or the out from pump line? Does anyone have a diagram of how this should all be plumbed?
Thanks in advance.
   / 3pt PTO log splitter. #3
You want the filter in the return (low pressure) side. I wouldn't want to see a filter with 1500 psi going through it. Did you mean 21 gallon or 2.1 gallon tank?
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2010 Dodge Ram 4x4 Crew Cab Pickup Truck (A59230)
2010 Dodge Ram 4x4...
2017 Ford F-550 4x4 Ext. Cab Mason Dump Truck (A59230)
2017 Ford F-550...
