3pt PTO log splitter.
   / 3pt PTO log splitter. #1
Bud Soda
Platinum Member
NC
Ford 5000, 3000
OK so I am going to pick up a powerhorse 3 point log splitter from Northern Tool. Instead of using my tractors rear hydraulics I want to use a pto driven pump. I plan on using a PTO pump by Prince with 21gpm flow. I will also use a 21 gallon tank and a filter.
I know the return (out from splitter) line will empty into the tank but do I install the filter in the return line or the out from pump line? Does anyone have a diagram of how this should all be plumbed?
Thanks in advance.
   / 3pt PTO log splitter. #3
You want the filter in the return (low pressure) side. I wouldn't want to see a filter with 1500 psi going through it. Did you mean 21 gallon or 2.1 gallon tank?
KOMATSU HM400-5 OFF ROAD WATER TRUCK (A60429)
KOMATSU HM400-5...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
