PhysAssist
Elite Member
- Joined
- Aug 22, 2011
- Messages
- 2,639
- Tractor
- Kubota B2320
Lovejoys are cheap and considered a wear Item on hydraulics. Just like belts, or chains and sprockets, etc. IF you check them every once in awhile, before the rubber is totally gone, you can get by just replacing the $2 spider...
What made you decide on the troybuilt over a speeco huskee from TSC???
I know they are real similar in price and specs, but havent followed them in awhile to know what makes them different.
As to the rest of the thread, my preference is a stand alone. I use the tractor and trailer with the wood in it, would be hard to do with the splitter on the back. But that isnt the main reason. Speed is. It takes a good sized tractor to be able to have the hydraulics that a small stand alone has. The OP talking about a MX5100 would only be about equal in speed to a stand alone. But a stand alone runs a small $100 motor that sips fuel.
Only way I would even consider a 3PH would be one with a stand alone pump and/or a regen valve. And by the time you add a PTO pump, the cost of the splitter is now as much as a stand alone model.
But its all preferance. If you dont want to maintain another small engine, and dont worry about going slow, then save a few bucks and get a 3PH.
For us, the 0% financing for a year was a balance shifter, because otherwise they ARE very similar, though not identical. Now that it's a couple of years later, I don't recall what the other factors were that made us go to Lowes.
Thomas
