3rd Function Diverter pressure relief
   / 3rd Function Diverter pressure relief #1
dstig1
Super Member
W Wisc
Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
Some of you may recall I have had problems with pressure relief on my 3rd function diverter that I added for my Grapple. No matter what I do to relieve the pressure it is always very hard to connect and requires me to use a bar clamp to pull the fitting tight while alternating relieving the pressure back at the 3rd function button on the joystick. Big PITA. Nothing else works. And to head off the obvious question, no it is not the fluid trapped in the grapple lines heating up in the sun. I could uncouple and then immediately recouple and the issue is still there.
So this got me thinking about some method of pressure relief I could add to this. What I had been thinking was figuring out how to add a 3rd line at the connections that goes back to the tank drain (should be low pressure, right?). Then putting T valves into the pressure lines to the drain line. A quick open/close should remove all pressure and keep the fluid in the system, right? The trick is never forgetting to close those valves...or there would be trouble.
Then I went and rented a big skid steer a couple weeks ago. It had auxiliary hydraulics on it, and lo and behold had a setup that is made to drain residual pressure with 3 connections on it. A little searching online and I found this "Saturn block". It was a different model than what was on the Bobcat but same principle. Baileys has the best price I found:
Quick Couplers 237-515 Detailed Information
So I was thinking of giving that a shot, perhaps, instead of my manual version. I'd probably end up with as much in parts as this in any case. Looking for thoughts and suggestions here. I also need to figure out where I can tap into a drain line and how to do that. I assume there is one at the loader control valve block?
   / 3rd Function Diverter pressure relief #2
I have mentioned this same procedure many times in the past.
If you wiggle the lever on the tractor, before your connect, and then open the needle valve in the tee fitting, it should work every time.
Another way is to use a dummy QD attached to a piece of PVC pipe with a rag in the PVC so the fluid never builds up.
Hoses should always be stored with dummy QD up, so fluid does not drain out.
Thanks JJ - To be clear - are you advocating the thing I was describing about adding a 3rd drain line and a manual valve? Parts start adding up quickly which is why I thought the "Saturn block" might be worthwhile. Either should work, I suppose.
Thanks!
   / 3rd Function Diverter pressure relief #4
All you need is a tee, and a needle valve.
The amount of fluid when you open the needle valve is probably no more that a tea spoon.
The only time a drain line would be important would be if you forgot to close the needle valve.
   / 3rd Function Diverter pressure relief #5
When I attach or detach my grapple, I shut down the tractor, turn the key back on without cranking the engine and toggle the switch a few times, then connect or reconnect. It works for me, at least.
   / 3rd Function Diverter pressure relief #6
There are QD's that couple under some pressure and others that couple under full pressure.
   / 3rd Function Diverter pressure relief #7
You could get full pressure couplers just for this one application. If you wish to keep the matching couplers on your third as the the others, just put together a short Adapter.
Couplers with threaded sleeves that draw the joint together would integrate your present pipe clamp system.
Or there are truely Quick couplers available.
Push to Connect - Connect Under Pressure Hydraulic Couplers
Might cost less than some other solutions.
Cheers
Cal
JJ - Gotcha. Thanks!
Grandpa - I wish mine worked that way. I do exactly as you say - It just never relieves the pressure enough to get it together by hand for some reason.
Cal - I really want to stick with the flat face couplers I have as most FEL equipment needing hydraulics will be skid steer type. I suppose the adapter section could work. I could even re-use the ones that are on the tractor for that. Still pretty pricey as many of those quick couplers are $50-100 ea for the specialty types. It's a thought. I'll look into options and see.
Thanks guys.
Well I finally addressed this and "solved" the problem. Since it is more of a PITA in the winter with needing to swap between the bucket and plow (with hydraulic angle), this got to be too much to fight with. I picked up a pair of flat face connectors from Bailey's that were touted as "connect under pressure" type (the ones with the black paint on them, if you are looking on bailey's). I swapped those out with the ones on the tractor side, then re-pressurized and tried connecting. It was improved. You are at least able to compress the fittings now, and one of them would connect by hand, but the other would not. The backup plan was to take the standard fittings I just removed, and screw them into a couple 1/2" pipe nipples with a 1/2" 4-way cross in the middle, and one fitting on each end. This is the pressure relief tool. If you can't connect by hand, use this to relieve pressure in the other fitting by letting a few drips of oil out, and then you can make the connection. Seems a heckuva lot harder than it should be, but it works now without resorting to clamps to pull it all together, so I will call that a success, I guess.
No pics at the moment, just thought I would update on what I had to go through to make this thing connectable by hand.
   / 3rd Function Diverter pressure relief #10
Is 1/2" standard pipe rated to the hydraulic operating pressures we see with reliefs set anywhere from 2000 to 3000 psi? I have used it on tank lines but never the high pressure side.
No, iron pipe is not rated for anything close to hydraulic pressure!! This pipe is open on the far end to the air and is really just used as a handle to hold the fitting and allow me to relieve the pressure by letting a few drops of oil out. It sees no pressure.
   / 3rd Function Diverter pressure relief #12
Ahhh, I didn't understand your post. sorry.
   / 3rd Function Diverter pressure relief #13
When ever I had trouble hooking up my quick connect fittings all I'd do is turn off the tractor, switch on the 3rd function button then push the left/right buttons on the 3rd function control handle to release the pressure and they attached perfectly. ALWAYS works with NO issues.
Paul, I have tried that so many tines it isnt funny... My old procedure involved having to use a bar clamp to press the fitting together and then tripping the diverter to relieve pressure. After anywhere from 1 to 4 times doing this it would go together. I am not crazy as my friend is currently having the same issue (he is storing it in exchange for using it to plow this wi ter at his new house). Only this has finally fixed it. It must be something about this particular diverter valve...
   / 3rd Function Diverter pressure relief #16
Ok just a thought. I know you are reliving the pressure on the system before you try to connect the hoses but are you turning off the tractor and releiving the pressure before you disconnect the grapple? The problem could be in the grapple hoses and not in the tractor hoses. Sorry if this has already been covered but I didn't see it.
   / 3rd Function Diverter pressure relief #17
I turn off the tractor, then move usually the FEL lever so that the pressure relieves. Occasionally, but very rare I open the relief valve on my backhoe when reattaching. Then disconnect the hoses and start the tractor back up.
   / 3rd Function Diverter pressure relief #18
Man that's very odd. I've done it that way on my 4240 and now the 5740. Actually did it today. So you shut down the machine. Turned the key to the on position, turned on the 3rd function switch then toggled both 3rd function buttons? Those quick connects should almost fall off. :confused:
Paul that is exactly what I do and more. I have toggled those fittings a million times after the engine is off and the the key back on. It is a colossal fight.n Everyone can give me the "is it plugged in?: Is it turned on? " routine to my deathbed and it still don't matter. It WON'T CONNECT...without a clamp and a couple rounds of hitting the button, once it is clamped under pressure.
The new "connect under pressure" fittings work a lot better, just not a total solution. I am sure the issue is in the solenoid valve somehow...just not sure how...
   / 3rd Function Diverter pressure relief #20
The new "connect under pressure" fittings work a lot better, jhust not a total solution. I am sure the issue is in the solenoid valve somehow...just not sure how...
Wow. That must be a royal PITA for you. I've never heard of anything like it. It's gotta be in the solenoid but if the solenoid works well with the engine running it still should work with the engine off and key on. J-J is the man here for this :confused: Sure hope it gets figured out.
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2018 KENWORTH T680...
2014 JCB 930 (A53317)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2021 CATERPILLAR 308CR EXCAVATOR (A60429)
2021 CATERPILLAR...
2005 WESTERN STAR DUMP TRUCK (A60430)
2005 WESTERN STAR...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
