3rd SCV for 2320/2520?
   / 3rd SCV for 2320/2520? #11
That is great news. I hope it is not to long of a wait.
   / 3rd SCV for 2320/2520? #12
So if JD is comeing out with a 3rd SCV for the 2520. would it be better to wait on this ? instead of useing the foss diverter valve....:rolleyes:
i know with diverter i hear you haft to loose one of you functions while operating the grapple. so with 3rd SCV , will you get to keep all your functions and still be able to operate the grapple?....:)
   / 3rd SCV for 2320/2520? #13
kennyd said:
Chris,
I put rear remotes on my 4110, much the same way that YASH did his.
You can view the thread HERE and see it it clears anything up for you.
Thanks kenny. but i would haft to locate the valve in a different place.
as my backhoe seat and my 250 pound frame just fit between the ropes.:)
looks like my power beyond is mounted to the frame under where the backhoe seat is. but there is not enough room to put the big diverter valve.
i guess like everything. it would just take some thought...;)
   / 3rd SCV for 2320/2520? #14
Here is my take on this:
If you are just going to use the new circuit for a grapple, or for a FEL mounted snowplow, then there is no fear of "loosing one of your functions", as it only take seconds to open/close a grapple or angle a plow. Add to that the fact that with the hydraulic flow of our CUT's, you are not realistically going to do a bunch of operations at once anyway.
AND, if you use the 3rd SCV to operate the grapple or plow, you will have to take your hand off the joystick anyway to reach the 3rd SCV control.
Here is what I recommend:
Lets wait and see what the JD SCV kit looks like, and what it cost's before we go any further...
Oh, and by the way, I added a diverter to my FEL to operate a FEL plow that I had, so I am very familiar with hoe this all works. You can view that post HERE
   / 3rd SCV for 2320/2520? #15
Thanks for the advise. thats what i will do is wait for the 3rd SCV to come out before i make any changes....:)
My inquiry this week with the local dealer came back with a "not released yet from engineering."
David
   / 3rd SCV for 2320/2520? #18
Hi,
Does anyone have the 3rd SCV (LVB24871) installed on a 2520? If so could you post a picture of where it is installed, or describe where it is installed. I am thinking of getting it to control a Top-Link and/or my mower deck.
Thanks,
Jim Schroeder
   / 3rd SCV for 2320/2520? #19
Will see if i posted pics correctly. Not the best pic but appears that the valve itself sits just to the right of the operator near the rops. Should put the lever close to the three point control. Also need a power beyond to utilize this kit so can not utilize power beyond powered att at the same time as needing the third scv.
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53472)
2022 Quick Attach...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
LMC G500-500A LOT NUMBER 216 (A53084)
LMC G500-500A LOT...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
2014 RAM 5500 Bucket Truck - 4X4 - Cummins Diesel - Automatic Transmission -Versalift SST40 Boom (A53472)
2014 RAM 5500...
2020 CATERPILLAR 259D3 SKID STEER (A51246)
2020 CATERPILLAR...
