4&1/2" angle grinder reccomendations?
   / 4&1/2" angle grinder reccomendations? #71
To look for a good grinder, look at the amp rating, on the Dewalts 4 1/2" grinders there is a 5 amp which i would think is for light duty, then they make a 7 1/2 amp, and then they make a 10 amp which is alot stronger. We run into this alot at work when ordering grinders, the 5 amps dont last long at all, they get used alot also. But for home use it will be alot differnt, and the way they treat tools at work is not that great either. A person that buys his on tools will take much more care of them. But to me its the amp rating that makes a better grinder.
Now they have even a higher amp grinder for the 4.5 inchers. I think its 13 amp. I believe you are right...Ownership is the key to lifespan. Quite a few tools I have gotten back burned up or broken is some way.
   / 4&1/2" angle grinder reccomendations? #72
I have a old Makita I bought in oh, 1986? Back when they were red. I have used the heck out nof it, replaced the switch, cord, and repacked it. It still runs, but you can hear the slop in the gears now. I bought another one, but haven't used them much lately. The Best thing I did was get a 7" grinder; I should have done that 3 years into the first grinder....
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
Cummins 6-Cylinder Diesel Engine with Transmission (A55852)
Cummins 6-Cylinder...
UNUSED FUTURE CAT 301 ATTACHMENT SET (A57193)
UNUSED FUTURE CAT...
2012 MACK GU713 (A58214)
2012 MACK GU713...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
