4 cycle weedeaters??????????????
   / 4 cycle weedeaters?????????????? #1
BLUEBONNET2
harrison county, tx (NE TEXAS)
nortrac 25 xt JD zeroturn 54", briggs mtr.
good evening,
anyone got a 4 cycle weedeater? saw one today at the local Sears outlet....$200. looks nice and felt good when i picked it up, not much heavier than a 2 cycle..... /forums/images/graemlins/grin.gif
let me know /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
and a note to all TBN'rs and visitors, MERRY CHRISTMAS AND A GREAT NEW YEAR TO ALL /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
regards,
bluebonnet2
   / 4 cycle weedeaters?????????????? #2
I have a Stihl pole-saw with the 4-Mix engine. This is the same engine used on some of their trimmers. It is a four stroke with cams and valves but no oil sump. It uses pre-mixed oil and gas just like a two stroke. The pole saw engine starts easy, uses little fuel, turns high rpms, and will sit and idle all day long. It is heavier but I would not hesitate to buy a trimmer with the same engine. I can see it taking more maintenance.
   / 4 cycle weedeaters?????????????? #3
4 cycle engines:
last longer, are cleaner, use less fuel, require less maintenence and are quiter
on the down side:
are heavier, need more attention (oil changes), more expensive (in most cases) and sometimes dont like being upside-down
4 cycle weed eaters are good but 2 strokes are probably the best option. i own a 2 stroke but might go for the 4 stroke if i didnt use it to cut the hedge aswell
mith
   / 4 cycle weedeaters?????????????? #4
The Stihl 4-stroke uses oil mixed with the fuel as lubrication as does a 2-stroke. Therefore it can be run upside down and has no oil sump that needs to be filled or changed.
   / 4 cycle weedeaters?????????????? #5
so its more like a 3-stroke then /forums/images/graemlins/confused.gif
cross between the two
the ones ive seen here in the UK have separate filler caps for oil and petrol and take raw petrol
but i suppose that was abour 18months ago now
i stand corrected /forums/images/graemlins/grin.gif
mith
good afternoon,
today i bought a troy built 4 cycle weed trimmer at lowe's, $189. brought it home, put it together( detachable trimmer), put 30 wght oil in it, some gas, fired right up( easy pull), so far so good /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif.troy built has other attachments available /forums/images/graemlins/grin.gifmay get the chain saw later /forums/images/graemlins/wink.gif
will see how it goes in about six weeks /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif.
Also on the way home last night from work, stop in wally world for dog food and found a small (2 hp, 3 gallon) air compressor for $50... /forums/images/graemlins/shocked.gif, will test it later, had hose, some aditional items like a nozzle, tire fitting, etc. reg. price $98, just right for my small shop...... /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif
will keep you posted....
regards and thanks,
bluebonnet2
   / 4 cycle weedeaters?????????????? #7
congratulations on your new purchase
may i ask wether you have to mix the oil and fuel or does it go in seperate filler holes?
mith
good morning,
seperate fillers, one for gas, one for oil......the guy at lowes said that by 2006-07, 2 cycle motors will probably be a thing of the past due to EPA regulations. i don't know the details. this unit uses HD30 weight oil, about 3-4 oz. and regular unleaded gas.....1 year warranty /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
hope this helps.....you might try their web site(www.troybuilt.com) i bought the straight shaft model..
regards,
bluebonnet2
   / 4 cycle weedeaters?????????????? #9
Harbor freight has a 4 cycle trimmer on sale now for $79.99...............it also takes the various attachments. Ryobi, mtd, & troybuilt are all MTD brands now......... Trimmer .........I bought a couple 2 cycle trimmers from HF............Their recond models are alot of the time brand new overstock...........mine were...........Tom
   / 4 cycle weedeaters?????????????? #10
ofcourse price reflects quality - i think bluebonnet got a good price especially as it was a straight shaft (more rigid and robust)
still $80 for any trimmer is good - the engine alone cant be far off that
mith
Dixon Pro ZTR 2560 Zero Turn Mower (A53117)
Dixon Pro ZTR 2560...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
ASCO Transfer Switch (A52377)
ASCO Transfer...
Ford Tractor (A50120)
