MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 58,384
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
I had a similar situation back when I bought my current machine. There were 22 and 25hp options for the same frame. I divided the cost of each by the HP of each and they came out to the same dollar-per-hp.... that made me feel better for some stupid reason. :laughing:
Anyhow.... the factory recommended getting the higher HP if I was going to run the largest mowing deck they sold for the unit. You need the HP to keep the blade speed up when you hit thicker grass.
As for comments about weight doing the work..... NO. The engine does the work. Specifically, the pistons pushing long connecting rods turning the crankshaft does the work. The weight helps to transfer that power to the ground, but the weight does ZERO work.
If you have a choice, and money is not a problem, you'll not regret getting the highest power available for the frame size in the long run. Every machine runs out of power eventually as an operator gets used to it and tries harder tasks. With the higher power available, you'll reach that point further down the road, you'll have more reserve power when its needed, like heavy grass mowing, and you'll be able to run larger implements that will reduce your operating time in the long run.
Good luck with your decision making process. :thumbsup:
