4000 Twenty power questions
   / 4000 Twenty power questions #21
On a related note...the 3120 has the same engine displacment (90.1) as the 3520 and 3720. The turbo is the difference in HP. The 3320 is listed as 100.1 cu. in. Will the 3520 or 3720 get better fuel economy than the 3320 even with the increased HP, or does the pressure negate the lower displacement?
   / 4000 Twenty power questions #22
Without re-reading the whole thread, go to Nebraska tractor tests and dig. You'll find that the boost pressures go up about 2lbs per model.
   / 4000 Twenty power questions #23
Well, heck if it's all in the boost... why did Deere throw in the bigger block and not just throw a turbo on it and move it up the line to a 3520 and 3720? Like they did with the 402X series. Same engine just increased turbo boost and pump tweaking (or different pump).
AKfish
   / 4000 Twenty power questions #24
AKfish
I guess I didn't make myself clear. I was referring to the 4X20 series as the thread subject headline denotes.
   / 4000 Twenty power questions #25
OK, that makes sense. I was working off the last post from toulomne (sp?).
So... not to get off track here too far; but why would Deere drop the block size and then boost it on the 3520 and 3720?
Why not stick with the larger displacement engine and just boost that one?
Compete too much or overlap too much with the 4120?
   / 4000 Twenty power questions #26
Probably all of the above. Also, I believe the 3x20 series still use a Yanmar engine, while the 4x20 series is using a John Deere engine.
2015 MACK CXU (PINNACLE) (INOPERABLE) (A53843)
2015 MACK CXU...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
Hyster H225E Forklift (A47477)
Hyster H225E...
2018 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A53843)
2018 GENIE GS-1930...
2025 K3325G UNUSED Double Garage Steel Barn (A53117)
2025 K3325G UNUSED...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
