4010 Trans mule 2009 gas crew cab service for 325 hours
   / 4010 Trans mule 2009 gas crew cab service for 325 hours #1
Michelle K linnane
Esperance NY
JD 4103
Hi Guys
I am servicing my mule 2009 gas mule trans 4010 335 hours. I know what
filter for oil fram #4967
1.3 or 1.4 oil I believe it is 10W to 40W
Change air filter
Grease the one fitting
replacing the spark plugs
question 1) My question is there transmission fluid I know my gator did, but this go off engine oil?
question 2) What else should be looked at and adjusted?
question 3) As it has power steering does it have power steering fluid?
question 4) Cooling fluid how can you check?
As much of these things cost I am doing everything I can to take care of it. I use mine almost
everyday and could run game preserve without it. Does anybody know if manuals are online
anyplace. I am too cheap to buy it and can find the one I got with the machine.
   / 4010 Trans mule 2009 gas crew cab service for 325 hours #2
Hi Guys
Change air filter
Yes, there is transmission oil that needs to be changed at some point. Same goes for gear oil in the front differential.
There is no fluid for the power steering. It's electric.
Cooling fluid is usually checked by looking at the reservoir bottle under the front hood. You can drain the old fluid from a drain cock under the radiator. Just remember to take the radiator cap off first so it will drain faster. Wait until it cools down!
I found the service manual for my 2007 gas trans on-line for $7.00. Downloaded as a pdf then printed it.
Really not any other adjustments to make unless your parking brake isn't holding or the drive belt is slipping.
Good luck!
UNUSED RAYTREE RMLS18T-18 TON HYD LOG SPLITTER (A60432)
UNUSED RAYTREE...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2018 Toro Sand Pro 5040 Bunker Rake (A59228)
2018 Toro Sand Pro...
