40x64x12 Pole Barn started (and finished!)
   / 40x64x12 Pole Barn started (and finished!)
Nice barn and a quick build. Is the side "lean to" in addition to the 40' width? What is the size for the "lean to" rafters? whats the pitch of the main roof?
I just priced my pole barn size on their web site, their price is good, and what they quote for labor is good.
I believe they used 2x10's on the rafters doubled up. The 12' wide lean to is in addition to the 40' width for a total of 52'. The roof pitch is 4/12 on the main building and 2/12 on the lean to. btw, I didn't list it in the original post but the roof snow load rating is 35 vs. their standard 25.
HP
   / 40x64x12 Pole Barn started (and finished!) #32
Very nice. Just curious why you went 12' vs 14'? My barn is 44x52 with 12' walls and 2 7' doors and a 20' by 12' tall sliding door. I kick myself all the time for not going 14'. Can't get my boat, camper, neighbors dump truck, neighbors back hoe, ect in. 14' covers anything that can roll down the interstate.
Chris
I have no need for a building 14' high inside. 12 feet high seems cavernous. This pole barn is for our retirement years on a hobby farm.
Diamond Pilot - you have too much of your neighbor's stuff:D
HP
   / 40x64x12 Pole Barn started (and finished!) #35
Looks really nice! I like the way they finished off the sides of the lean to....I'm going to copy that because it looks a lot cleaner, and I have enough steel left over. The translucent panels are a nice touch. We used something similar as the roof center, so the whole length of the building is a skylight.
Yours went up a lot faster than mine did, but I had to work around a lot of additional factors. I opted for a poured foundation and anchoring the poles to the top of that, and I also had to pour 1/3 of the concrete slab, because it's plumbed for a full bathroom, and radiant heat. There was already city water and a septic on the site, so that sort of dictated a lot of things (like building placement).
We have an ordnance limiting the eave height to 14' max (without a waiver), so I stayed under it....think it's actually 13' since the large door openings are 12' high. I really wanted to have 14' high doors, but it was just going to be too much trouble getting another waiver, etc. Mine is also 40x64 with a 12ft lean to off the back (guess that makes it sort of 54x64). I may extend it at some point, and I'd put a high lift rollup door on the end in case I want to park an RV inside.
This was the day before the doors were hung:
This is what the skylight looks like:
I started out with a manufactured home on the lot, so we had to do demo first....made up a Photobucket album showing the process if anybody needs inspiration!
Barn Photos by G-ManBart | Photobucket
Nice building there Gman. Those look like more stout trusses than I have - I would imagine you have quite a bit more snow than we do in our area.
   / 40x64x12 Pole Barn started (and finished!) #37
HP
thanks, that is a really nice looking barn.
   / 40x64x12 Pole Barn started (and finished!) #38
Great barn Gman and I'm thinking to use your idea for my barn (free natural light). Looking at the picture I can't see any braces used between trusses (e.x: cross, wind, diagonal, horizontal). Do you have some or the barn is protected from any lateral wind?
   / 40x64x12 Pole Barn started (and finished!) #39
HP
I thought the same. Give it time.
Chris
   / 40x64x12 Pole Barn started (and finished!) #40
Well, I can't take credit for the skylight idea...I just told my roof/walls/siding guy that I wanted a couple of skylights. I'm pretty sure this is the brand/version he used:
Pro-Sky® Ridgecap
Yes, there are cross braces, diagonal, etc, but I don't think many were in place when I took that picture. I had to walk, climb, crawl around them when I was stashing the leftover steel sheets up there!
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A55787)
2025 Single...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54313)
2017 FREIGHTLINER...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2019 INTERNATIONAL...
Ford Pickup NR (A50323)
Ford Pickup NR...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 66"...
