4110 owners - PAY ATTENTION !!
   / 4110 owners - PAY ATTENTION !! #1
skipmarcy
Erin, Tenn.
2001 Mahindra 4110
I've had my 4110 for 3 years now, have 690 hours, and have been extremely happy with it up until about 2 weeks ago, when my problem hit me. My tractor would make a horrendous noise when trying to lift a loaded bucket which I found out was the flywheel rubbing the nosecone off the starter !! That was just the beginning of the damages though. What had happened was when they assembled the tractor they didn't use Loc-Tite on the bolts that hold the engine to the mainplate and 8 of the 13 bolts had loosened and snapped-off in the block and the other 5 were about to fall out - the tractor was about to come apart. There was no forewarning of this, either. I maintain my tractor well and there were no visible signs of the bolts coming out. I got all the bolts out and replaced them, but after reassembly I found I had a severe problem with with the clutch/front trans. and had to replace the pilot brg., release brg., clutch disc, pressure plate, input brgs. on the trans. and still have a problem !! I believe the syncro. assembly is also damaged in the linear trans. and will have to split it again and spend no telling how much more in parts. The only way to check these bolts is to split the tractor, or possibly to remove the starter and use a mirror & light but this won't let you see all of the bolts. 11 of the 13 bolts are behind the flywheel and you can't use loc washers because of clearance, so Loc-Tite is mandatory. My factory bolts had absolutely none on them. They did use Loc-Tite at several other locations, can't believe they let these bolts go. Of course I'm out of warranty for a year now, so it's all on me. Mahindra wanted way too much for parts so I searched and got most of it in aftermarket. Bearings were easy to find from numbers on the old bearings, just have to find a parts guy willing to cross-reference them, clutch parts were more elusive but found a reman. supplier in Iowa and also found that the clutch disc & pressure plate fit a Massey 1160 or 1165. I'm afraid I'll have to get the trans. parts from Mahindra, haven't checked into that yet. Otherwise, my tractor has been a good one.
   / 4110 owners - PAY ATTENTION !! #2
Did you try to contact your dealer or Mahindra about this?? Maybe, just maybe, they might assist you in some way. I know some manufacturers will still assist in various ways even when the product is out of warranty. For example, Polaris paid for the parts on my Ranger when it was out of warranty, and I paid for the labor only on a recent steering box problem. It did save me some money. Heck, Toyota rebuilt the engine in my 1998 Camry with 103K miles FREE OF CHARGE.
You should be contacting Mahindra and your dealer regarding this problem. I will be checking my 4110 today. Thanks for the "heads up".
   / 4110 owners - PAY ATTENTION !! #3
Skip,
Your post is both informative and at the right time for me. My wife and I were going to see a Mahindra 3510-4110 tomorrow and possibly put down a deposit. However, with your unfortunate problem, we will wait and see what the factory does in your case and follow this thread. Sounds like the "problem" started at the point of origin and, IMHO, should be taken care of by the manufacturer. What the factory does will sway my decision.
Good luck!
Bob /forums/images/graemlins/wink.gif
   / 4110 owners - PAY ATTENTION !! #4
WoW! Thats a new problem unheard of before.
Maybe we can get some dealer input on this and if they have seen this happen on tractors they sold.
Unfortunately for you, it could be an isolated insodent.
   / 4110 owners - PAY ATTENTION !! #5
I'm confused"
I thought 4110 was a John Deere model for a compact tractor. Is the same model number used by two different
manufacturers. I have a JD 4110 tractor setting in my garage
that I bought in july of 2004. This other brand is using the
same numbers? Where am I missing something?
Thanks for any information on my confusion.
   / 4110 owners - PAY ATTENTION !! #6
I would be very surprised if the manufacture will help any. And as far as I know, loctite is not used on the engine to transmission joint by an manufacture. A large, high pressure joint on any tractor that has been taken apart needs to have it bolts retightened or at least checked after a few hours of use, just like a lot here have found that they need to check their lug nuts. Having said all that, good luck with getting help on it.
   / 4110 owners - PAY ATTENTION !! #7
</font><font color="blue" class="small">( A large, high pressure joint on any tractor that has been taken apart needs to have it bolts retightened or at least checked after a few hours of use )</font>
Jerry,
I don't believe ( could be wrong here) the problem loose bolts on this machine had ever been taken apart prior to coming loose.
   / 4110 owners - PAY ATTENTION !! #8
Unlike cars & trucks you can tell a manufacturer from a model name, tractor companys may have same model numbers so you need to realize the manf. before the model number.
Model numbers on tractors are based on series and horsepower within a manf. lineup.
Yes it can be confusing, think of it as two sports teams, different players, same number on jerseys. /forums/images/graemlins/grin.gif
   / 4110 owners - PAY ATTENTION !! #9
</font><font color="blue" class="small">( Skip,
Good luck!
Bob /forums/images/graemlins/wink.gif )</font>
I wouldn't make a purchase decision based upon a single incident. There are too many variables when looking at the causes of a problem like this.
   / 4110 owners - PAY ATTENTION !! #10
Keith,
No problem here, just watching intently. My wife really likes the 3510 over every tractor I've looked at because of the ML112 loader strength for moving large haybales. She even gave me the okay to get the quick attach loader for a bale spike! We understand that every now and then a fluke manufacturing problem occurs. It can happen to any tractor out there.
Thanks,
Bob
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
2010 Chevrolet Malibu Passenger Car (A51694)
2010 Chevrolet...
199049 (A51243)
199049 (A51243)
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
Miller Wildcat 350-D Welder (A51691)
Miller Wildcat...
