4200 no 4wd
/ 4200 no 4wd #1
Mighty Dodge
Platinum Member
The Hereford Zone, MD
JD 4200
I was digging potatoes today and noticed my tractor won't go into 4wd. The shift lever moves but it doesn't engage and the light doesn't come on either.
What happened?
M.D.
/ 4200 no 4wd #2
Hopefully the light bulb burnt out, but I doubt your going to get that lucky.
Good luck with it.
David from jax
/ 4200 no 4wd #3
What happened?
M.D.
Does the lever have resistance when moving? Could it have a broken linkage?
/ 4200 no 4wd
The roll pin in the linkage was broken. It moved the shifter shaft a little but not all the way. Fixed it.
M.D.
/ 4200 no 4wd #6
M.D.
Exact same thing happened on my tractor a couple of years ago. Easy fix once you find out why it won't work. Sometimes finding the problem is more than half the battle.
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
2005 Infiniti FX35 AWD SUV (A66738)
2005 Infiniti FX35...
2021 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A66736)
2021 Chevrolet...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2009 ALLMAND  MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
YALE GLC060VXNDAQ084 WAREHOUSE FORKLIFT (A69058)
YALE...
