425 mower not engaging
   / 425 mower not engaging #11
Dutch
Interesting you say hydraulic clutch. However there is an electric switch to engage the clutch, so that may be where the thinking is that it is electric.
I thought it was electric, that the switch would activate a magnet that would either release or engage the clutch plates in the transmission.
Can you fill us in with more detail how that PTO clutch works?
   / 425 mower not engaging #12
Well... I just went through the wiring and do not see any anomolies near the front of the tractor. Took the connectors off and cleaned them where I could. It appears that the wires from the PTO switch go into the circuit board on the right side of the tractor.
There is a green light and a red light on the panel. Any ideas what they mean?
I am going to have to remove the seat pan and gas tank to get to the wires that go into the tranny, and I don't feel like ripping that all apart today. I have a feeling that I would not find any issues under there anyhow.....
the serial # is M00425B071. It is a 1999 I believe. Thanks!
Appears this tractor has the reverse shutdown switch. Has it been disabled, and is somehow acting up now?
Attached the PTO schematic if that might help. If more on the trouble-shooting section of the PTO is of interest, I can post that as well.
   / 425 mower not engaging #13
Here are some additional pages from the tech CD that might help. Wondering if it could be the solenoid valve too, or a wire going to it?
   / 425 mower not engaging #15
Book says to put 12v on the pto clutch solenoid after disconnecting from main circuit and listen for a click. Check clutch ground, too.
Beenthere - Thanks for those troubleshooting pages. I think I am going to print those little puppies out!
The problem now guys is that I am at work for the week so I will not have a chance to troubleshoot until next week. Grrrrr....:mur:
   / 425 mower not engaging #17
Scotty,
that's the difference from the electric clutch to the hydraulic,
there is no air gap adjustment. the clutch is enclosed in the
transmission and quite durable.
but, there may still be an electrical problem getting there,
there is the solenoid that activates that clutch
Have you checked the air gap adjustment in the Electro clutch? Check my prior thread on simular problem on 318. http://www.tractorbynet.com/forums/...44369-jd-318-intermittent-electro-clutch.html
   / 425 mower not engaging #18
One difference with these units is they don't have
an electric clutch. there is a hydraulic clutch in the
transmission.
there is also an electronic control panel on the right
side of the steering column with some lights, red/green.
there are relays on the board, and i was experiencing
intermittent problems with pto engagement until i replaced
the circuit board. at the beginning, i think i remember that
i was able to tap the relays and the deck would come on.
look into that area and see if you come up with any more
info. double check the lights that come on and when.
(the red/green ones)
I was wondering what all that stuff on that circuit board was for.
   / 425 mower not engaging #19
Dutch - That's what I was afraid of. Just tryin' ta help if they were simular designs! ~S
Ok. Got it figured out. It was the solenoid in the rear of the transmission that engages the PTO. It was bad and replaced. Works great now :thumbsup:
Only problem is the dang thing was $100 from the JD dealer :shocked:
2010 Kubota ZD326 60in Zero Turn Mower (A55851)
2010 Kubota ZD326...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
2004 INTERNATIONAL 9400I DAYCAB (A55745)
2004 INTERNATIONAL...
2008 Featherlite Trailer, VIN # 4FGE853218C108480 (A53424)
2008 Featherlite...
PALLET OF (10) BRAKE DRUMS (A55745)
PALLET OF (10)...
STORAGE SHELTER KIT (A53843)
STORAGE SHELTER...
