430 bucket teeth
   / 430 bucket teeth #11
Re:toothbars
John -
I'd run out to the shop and measure my bucket, but it's dark now. Plus my shop is 120 miles from my house. /w3tcompact/icons/laugh.gif
It's a Kubota LB400-A, which is spec'd as 60.0 inches wide. Don't know if that's an inside or outside dimension.
If I can get a new bar for 250 bucks, this thing might just happen! Dang it, John -- you're getting me all excited again! /w3tcompact/icons/crazy.gif
Thanks for the info!
And Bird -- thanks for sharing your attack of laziness with us. Twenty bucks for having it done right (should the need arise) sounds like a bargain. I've hired a local welder up at the property only once so far, and that was to create and install a couple of wrought iron railings to help my mom down the 2 front steps. The guy was expensive ($400 for two short railings), but he came highly recommended by all the neighbors. In fact, I had to get on a waiting list to get the job done. I was surprised when he showed up with only a well-used oxy/acetylene rig. But even more surprising was that he was in a wheelchair! /w3tcompact/icons/shocked.gif A total paraplegic, he abandoned his chair to do the actual welding and just dragged himself around to get the job done. This guy was part welder and part artist, both to an impressive degree.
Dunno if he charges less for doing industrial grade work (which he is said to do equally well), but it would be interesting to see what he can do.
   / 430 bucket teeth #12
Re:toothbars
<font color=blue>60.0 inches wide. Don't know if that's an inside or outside dimension</font color=blue>
Outside, I'll bet, so the toothbar needs to be ~5/8" shorter, but you need to measure to be sure. A toothbar that's just a little too short (fraction of an inch) is no problem; just use washers on the inside of the bucket for spacers, but if it's just a little too long; time for the welder.
Bird<P ID="edit"><FONT SIZE=-1>Edited by Bird on 04/17/01 08:20 AM (server time).</FONT></P>
   / 430 bucket teeth #13
Re:toothbars
Hi Guys, I'm back for a bit. I got my new set from shearfer equipment, Just under $300. including freight, same brand bird has.
DDT
   / 430 bucket teeth #14
Re:toothbars
· Toothbars are custom made to fit your bucket
· 1" wide shank allows easier penetration into hard compact materials
· Shanks are made of T-1 material
· Shanks are protected by replaceable points, giving you a longer lasting toothbar
IMPORTANT INFORMATION
When ordering toothbars, give the exact inside width of the bucket and the thickness of the cutting edge on the bucket. Toothbars may be made slightly longer or shorter than the lengths listed to accommodate custom bucket widths. For buckets with bolt-on edge, check for width & tooth combination availability.
Toothbars for Buckets w/Standard & Bolt-on Edge
P/N Approx.Weight No. of Teeth Approx.Width
1036 44 lbs 5 36"
1042 49 lbs 5 42"
1049 56 lbs 6 49"
1054 64 lbs 6 54"
1063 73 lbs 7 63"
1072 83 lbs 8 72"
1082 93 lbs 9 82"
1064* 78 lbs 7** 63"
1073* 88 lbs 8** 72"
1079* 98 lbs 9** 80"
· Toothbars for buckets with bolt on edge,** Quantity of teeth may vary depending on bolt hole pattern.
Also have available Manufacturers Model # of Loader and Bucket.
K.C. Canary – 800 920-7097, Ask for Mark in sales
Tell Mark it’s an Internet Order and John Miller sent ya…{he may charge you more /w3tcompact/icons/smile.gif}
Current price on 54" is $240, 63" is $260. + freight from the Midwest.
   / 430 bucket teeth #15
Re:toothbars
Bird...
Didn't you know... That's why God invented grinders.../w3tcompact/icons/smile.gif
   / 430 bucket teeth #16
Re:toothbars
I nominate John Miller III for "poster of the month"./w3tcompact/icons/smile.gif I will be ordering a toothbar for my 430 loader as soon as I can take some exact measurements. Thanks for all the information.
Fugitive from the Cubicle Police
   / 430 bucket teeth #17
Re:toothbars
Yeah, I know, John, and one of these days I'm going to have to buy a bigger, heavier duty one than I have now./w3tcompact/icons/laugh.gif
Bird
   / 430 bucket teeth #18
Re:Toothbars Available for all buckets
Harv, most people don't realize that 90% of New York is rural, and extends 300 miles North of New York City. I grew up in New York's largest county (St. Lawrence) where the cows outnumber the people by a large number. For that matter, I think the deer and bear outnumber the people also.
As far as the 430 teeth, I like them.
   / 430 bucket teeth #20
Re:toothbars
Oh No..., give it to Bird... the last time Harv got <font color=blue>poster of the month</font color=blue>... you saw what happened to him/w3tcompact/icons/frown.gif He now pays $1000. month dues./w3tcompact/icons/wink.gif
Besides, you know what they say about Texas...everything is bigger... bigger wallets, bigger retirements....
Right Bird...?/w3tcompact/icons/blush.gif
Year: 2005 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2005 Make...
2002 Ford F-650 Landscape Flatbed Truck (A56858)
2002 Ford F-650...
2025 GPS Equipment Trailer (A56858)
2025 GPS Equipment...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
Landoll Lowboy Trailer (A56435)
Landoll Lowboy...
