4310/4410 whats the difference
   / 4310/4410 whats the difference #31
JMIII
Great stuff. Can you post the chart for the 4TNE84? (I think that's the 4510/4610 engine). That should settle this 4410 vs. the 4-cyl engines torque question once and for all. /forums/images/graemlins/grin.gif
If I read the bottom chart correctly - it looks like there is no fuel usage penalty worth mentioning with the bigger 4710 engine - that is if you're drawing 30HP on the PTO for a mower under a given field condition - both engines are going to consume exactly the same amount of fuel per hour? (OK - with maybe a tick more just moving the heavier 4710). But - you have the "reserve" power available in the bigger motor when needed.
   / 4310/4410 whats the difference #32
Are these charts specific to Yanmar OEM engines? Could it be that in the Deere application, other factors such as injector pump specs affect this? I really don't have a clue, just wondering....
   / 4310/4410 whats the difference #33
Can I say, I love my 4300 /forums/images/graemlins/grin.gif
(my wife can verify that) /forums/images/graemlins/shocked.gif
   / 4310/4410 whats the difference #34
OK. Someone who's more of an engineer than I (I do software, my brother's the ME) can say if this is wrong - and please do /forums/images/graemlins/blush.gif, but I've always read it that torque and hp are directly and mathematically related.
Torque (lb-ft) = (Horsepower * 5252) / RPM of Horsepower rating.
Since the JD engines are all rated at the same RPM (2600) that factor goes away. Therefore the relative torque output is directly related to the relative HP of the different engines - there's no "hidden" torque-creating factor involved. There's a lot of factors (stroke length, piston area, swept volume) that come into play to get to those numbers, but once you're there - hp and torque and rpm are all glued to each other.
The 4410/4510/4610/4710 deliver 35/39/44/48 hp (gross) respectively - and since this is all at the same rpm - the torque at that rating rpm *must* increase in that order. The 4410 can not be in 2nd place (unless the hp ratings are wrong.) Now what happens at other rpms can definitely vary from that order - but from JMIII's charts it looks like the engine series are very linear in their growth.
I'll chalk the rest up to misprints in JD's literature. /forums/images/graemlins/grin.gif (and apologies for going so far OT)
   / 4310/4410 whats the difference #35
</font><font color="blue" class="small">( did you work with the CIA? )</font>
Later, when I have more time... I'll tell ya a true story about the CIA... /forums/images/graemlins/wink.gif
   / 4310/4410 whats the difference #36
Yanmar's Diesels
..JD4310....................Yanmar Powerplants.............JD4510/4610..
   / 4310/4410 whats the difference #37
</font><font color="blue" class="small">( Are these charts specific to Yanmar OEM engines?)</font>
Yes...
</font><font color="blue" class="small">( Could it be that in the Deere application, other factors such as injector pump specs affect this? )</font>
Yes...
The mfr. will usually show their "best face" when it comes to spec's... so I'm assuming these charts as continuous duty to do just that... but like any engine... you can tweak them up/down... /forums/images/graemlins/smile.gif
   / 4310/4410 whats the difference #38
</font><font color="blue" class="small">( but like any engine... you can tweak them up/down.)</font>
So it IS possible that Deere has the 4410 set a little "hotter"; seeing it is their largest offering in that frame size. If a buyer wants a particularly "hot" unit in a mid chassis - they might be willing to pay a premium. Actually price is seldom tied to fixed cost of production, but on "price points" or sometimes, even snob appeal.
I, personally, may well be in the range of the 4410. I need all the power I can get, but the mid frame size would be a plus, with a gazillion trees and crazy topography to traverse.
I have checked all over and I think the torque number is right for the 4410, and the 101ci is the right displacement. I sure don't mind being corrected, if that could be verified. /forums/images/graemlins/crazy.gif
   / 4310/4410 whats the difference #39
Timb,
You are correct - at a given rpm torque and HP are directly related. My earlier post may have been misleading - I was trying to "rationalize" JD's numbers - which appear to be wrong. I hadn't looked at the rated rpm - which is critical. It appears that the JD 4X10 line has a nice linear progression for hp and torque - you pay more you get more.
Bill
   / 4310/4410 whats the difference #40
This subject has haunted me. From a very little digging I got the following from the Deere Owners Manual for mid-chassis CUT's Thia restates JMIII's info,, from Deere's angle.
By no means should it be considered inerrant /forums/images/graemlins/shocked.gif
<font color="green"> Manufacturer Yanmar
Model Number (4210) 3TNE82A
Model Number (4310) 3TNE84
Model Number (4410) 3TNE88
Type Diesel
Cylinders 3
Gross Horsepower (4210) 20.2 kW (27.0 hp)
Gross Horsepower (4310) 23.2 kW (31.2 hp)
Gross Horsepower (4410) 25.8 kW (34.6 hp)
Manufacturer's Estimated PTO Horsepower (4210 SyncShift) 17.5 kW (23.5 hp)
Manufacturer's Estimated PTO Horsepower (4210 eHydro) 16.4 kW (22.0 hp)
Manufacturer's Estimated PTO Horsepower (4310 SyncShift and ePowrReverser) 20.1 kW (27.0 hp)
Manufacturer's Estimated PTO Horsepower (4310 eHydro) 19.0 kW (25.5 hp)
Manufacturer's Estimated PTO Horsepower (4410 ePowrReverser) 22.4 kW (30.0 hp)
Manufacturer's Estimated PTO Horsepower (4410 eHydro) 21.3 kW (28.5 hp)
Rated Engine Speed 2600 rpm
Operating Range 1000-2810 rpm
Engine Torque @ Rated Speed (4210) 71.0 N·m (52.4 lb-ft)
Engine Torque @ Rated Speed (4310) 78.5 N·m (57.9 lb-ft)
Engine Torque @ Rated Speed (4410) 87.9 N·m (64.8 lb-ft)
Compression Ratio 18.5:1
</font>
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2005 Isuzu NQR 4 door box truck with folding gate (A56438)
2005 Isuzu NQR 4...
