4320 with water in oil
   / 4320 with water in oil #1
billkater
Bronze Member
Olney, Il. Home of the White Squirrel
New Holland 1715
My dad's 4320 ag tractor is getting water in the oil. Not a lot but It is there. It is a 1972 I believe. Are there any places to start looking? Something that is very common problem with this tractor?
Also, does this have sleeved cylinders that may have a leaking o ring?
Bill
   / 4320 with water in oil #4
I have pulled the sleeves on a couple of smaller John Deeres in the last few months. On my sleeves there are two o-rings per sleeve. The sleeves on both engines had some pitting and corrosion on the sleeve at the upper o-ring. If water is getting past the o-rings I'll be surprised if the sleeves are serviceable. I think odds are that you will want/need to replace the sleeves.
   / 4320 with water in oil #5
Ditto on possible engine piston liner failure but engine oil cooler or possibly head gasket could be leaking. One can remove engine oil pan then pressurize cooling system to check for liner/o-ring leakage. Has engine coolant been changed regularly or had PH monitored?
No. Has had neither done.
   / 4320 with water in oil #7
A failed engine oil cooler is less common to occur and far more likely to put engine oil into the cooling system than vice-versa.
   / 4320 with water in oil #8
WET sleeves as someone else mentioned. I did my 74 2630 about 5 years ago. Back then the new sleeves pistons bearing and gaskets was around 800 bucks.
2025 Mower King SSECAG-Y (A50123)
2025 Mower King...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
2011 Freightliner M2 106 Ambulance (A51692)
2011 Freightliner...
2011 John Deere 4520 53HP Loader Utility Tractor (A51691)
2011 John Deere...
2011 Ford F-150 4x4 Pickup Truck (A51692)
2011 Ford F-150...
