4400 john deere starting problems
   #1
Leroy excavator
John deere 4400
I have a 4400 john deere tractor that quit running and will not turn over. Have power but no contact when switch is turned to start. Pump solenoid will not click either only dash lights will work any ideas of the problem?
   #2
super55
Platinum Member
Great North of Michigan
Oliver Super55, John Deere 4310, John Deere 4400, Kubota L2500 (had)
My 4400 had a similar issue years ago. Accessories would work, Try to start it would click a couple time and then all electrical and then come back after a few minutes. My situation actually ended being the battery posts. I cleaned the grounding point and then put new battery posts on and it solved the problem.
Not to say yours is having the same issue but it is definitely an area you want to look over.
fried1765
Super Member
Northeast & FL
Kubota L48 TLB, Ford 1920 FEL, 8N Ford, Gravely 12 HP "Professional", 48" SCAG Liberty
What type battery has replaceable posts?
super55
Platinum Member
Wasn't the battery posts it was the terminals that go to the posts. My positive lead had about 3/4 of the copper strands broken. It was still able to carry low amperage to the accessories but as soon as you tried to crank the starter it couldn't handle the amperage.
Honestly I thought this happening was kind of a rarity but last year the connectors for the battery on my boat had the same exact thing happen.
Williy
Platinum Member
Texas
Yanmar YT 235C Yannar YRC 60 rotary cutter, Yanmar RT72 rotary tiller B75 Backhoe & bucket
you need to clean your battery posts the the connectors that go on the battery posts and check the ground connection from the battery. Get
some dielectric grease from amazon or where you can find it this will
help keep the connections clean from corroding
better yet just get a cheap vom meter and go on youtube how to use
a vom meter. With this knowledge you can trouble shoot your system
willy
CoyPatton
Veteran Member
Poplar Bluff, MO
Yanmar YM2002D with Koyker 110 FEL
Does the terminal from the switch have 12 volts where key is turned to start?
Does the starter solenoid click when key is turned to start?
Your limited supplied information makes it difficult to provide suggestions.
It could be the battery and/or battery cables/ connections or safety switches.
Many including me are willing to offer suggestions, but we need info.
