4410, 990, 4120, 4320, 4520, 4720...Which One?
   / 4410, 990, 4120, 4320, 4520, 4720...Which One? #31
Dave,
Just curious I guess! It seems that you are pondering the 4410 vs. the 4320. Big difference in machines there Hp wise, seeing the 4410 is 35 hp while the 4320 in 48 hp. Have you considered the middle man there in the 4120, it appears to be some $2000 and change cheaper and still puts out 43ish Hp. Personally I have a little more than 2 acres of meadow I generally keep 8" or less with my 4310 and lx5. At a good clip I knock it down in usually around an hour, with only 3 trees to dodge. I guess I could get away with a 6' but I feel the 5' is a better fit as I don't have much to cut and is better matches with my pto hp. Brother in law has the 4120 with power reverser and runs a woods 6' hog roughly equivelent to the mx6. Does it with ease and cuts around 10 acres. That's my 12 cents wirth. Happy cutting!!!
4310man
   / 4410, 990, 4120, 4320, 4520, 4720...Which One? #32
Excellant reasoning, Dave. Excellant choice!
   / 4410, 990, 4120, 4320, 4520, 4720...Which One? #33
Dave,
Sounds like it's going to be nice machine for you, congrats.
Careful getting too wrapped up in the spec numbers, especially if they're published by Deere. Much as I like green - they're notorious for typos in their literature. Example - the 4710 is rated at 48.1 hp @ 2600 rpm. That translates to 97.2 ft-lbs. torque at rated speed. The 4320 is also rated at 48.1 hp but @ 2400 rpm for 105 ft.-lbs. It's a simple formula, but Deere's published numbers hp/torque have never quite added up, so either the published hp or the published torque numbers (or both) are often off a bit.
In ANY case - plenty of power - and I think you're going to like your green machine. One option I'd suggest before you take delivery - look at the extendable draft links (and/or a quick hitch). I've found the links to be VERY helpful wrestling my MX6 off and on since I don't have a pool-table flat area to work with.
   / 4410, 990, 4120, 4320, 4520, 4720...Which One? #34
Dave,
I'm sure that you will enjoy the machine as much as I do mine.( 4320 400X loaderw/ JD four in one bucket,448 hoe,MX6 RC)
I bought the I-Match to aid in hooking up to the cutter and any other attachments that I will end up with and love it.
the machine is very well sized for your application.
Enjoy!
   / 4410, 990, 4120, 4320, 4520, 4720...Which One? #35
Congrats FLDave! You'll love it! I do mine!
Hate to say it but you may beat me getting those **** pics up! Had to go another route to be able to get on the computer.
Working out of town hasn't helped this week!
Supposed to get a lot of snow tomorrow, can't wait to get home.
<font color="green"> </font> Rob
Michigan /forums/images/graemlins/smirk.gif
   / 4410, 990, 4120, 4320, 4520, 4720...Which One? #36
Dave:
(I looked at it backwards.) Well...yes you did and inside out, upside down and any other way you can look /forums/images/graemlins/grin.gif
You got yourself a beast and in a lovely shade of green to boot....enjoy and welcome to the green ownership club!
Whiskey
Ok, the driver beat me to the property so it was off the truck already. /forums/images/graemlins/tongue.gif
Front view...it will never be cleaner. /forums/images/graemlins/wink.gif
73" heavy duty bucket with hooks added. Look not a scratch. /forums/images/graemlins/grin.gif
Operator's station...that's me...the operator that is... /forums/images/graemlins/cool.gif
2020 FORD F-250 SUPER DUTY (A52472)
2020 FORD F-250...
1264 (A50490)
1264 (A50490)
2019 Nissan Sentra Passenger Car (A51694)
2019 Nissan Sentra...
2020 Peterbilt 520 T/A Cab and Chassis Truck (A51692)
2020 Peterbilt 520...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
