450' wiring conduit -how to assemble?
   / 450' wiring conduit -how to assemble? #61
With electrical conduit, you use a different type of glue on the joints then with PVC or CPVC. This glue is clear, but doesn't use primer. It's not designed to hold high water pressure, or even any water pressure. The glue just has to be strong enough to keep out the water from getting in under normal, gravity conditions.
Use the right glue, and it won't harm the wire casings.
I can lay out the wire and slide the pipe over it fairly easily. It's time consuming, but when it's done, it's a simple matter of putting it in the trench and moving on. With pulling wire, it's a task of how much effort to pull it and what to use to pull it. I've done both, and while working by myself, I always slide the pipe over the wire. It's just allot easier in my opinion.
Eddie
Another reason for conduit - I "thought" I had left plenty of cable at both ends. When we came out of the ground to inside the barn then into the panel we were 6" short!
We were able to use the FEL bucket hook to gently pull all the cable we needed. If I'd gone direct burial, I would have had a real mess on my hands.
I would go with the slide-on method again. I didn't find gluing up the sections to be a problem.
Again, a big thank you for all the help here.
EZGO (A50324)
EZGO (A50324)
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
2021 BOBCAT T870 SKID STEER (A52705)
2021 BOBCAT T870...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
