4500 years of manufacture
   / 4500 years of manufacture #21
Messick's (New Holland Parts Lookup Online Catalog) says 4500 was manufactured 1/65-12/74.
The 4500 is basically a 4000 and has the numbers as a 4000.
If you are lucky there is still a readable tag on the underside of the hood, above the battery. At FORD CODES and SERIAL NUMBERS you find information on where to find numbers on other places and what they mean.
hey I just wanted to say THANKS to you for posting that link on serial #'s and codes , that is the most helpfull piece of information that I have seen yet on this subject
OK, I finally got back to this beast. the hydraulic filter is NASTY!!. the stuff that came out with the filter looks like matted cat fur. The hard plastic around the top of the filter ring is all falling apart also. I can't find a number on it anywhere so does anyone have a NAPA number for the main hydraulic filter. thanx , crossy
   / 4500 years of manufacture #24
   / 4500 years of manufacture #25
There is also a suction filter (Item #67 in the Messick's diagram), perhaps you already have cleaned it.
I have never serviced a 4500, as it turned out I have a Users Manual and took a picture of a figure that may be of use for you. Come back if you need information from the manual text. I think someone else on the forum is better to guide you, but the figure may assist.
I have to figure out exactly where that suction filter is. that thing HAS to be clogged with the crap i saw in the main filter. looks like it is in the supply piping to the pump. thanx , crossy
   / 4500 years of manufacture #27
Hakan's picture shows where it is, at the tank outlet to the pump.
(3) SAFETY CONES (4) PIECES OF 3" PIPE (A58376)
(3) SAFETY CONES...
2014 Case 601D Directional Drill (A57453)
2014 Case 601D...
2005 Isuzu NQR 4 door box truck with folding gate (A56436)
2005 Isuzu NQR 4...
John Deere 4820 Forklift (A57453)
John Deere 4820...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2017 Mitsubishi Mirage G4 Sedan (A56859)
2017 Mitsubishi...
