4500 years of manufacture
   / 4500 years of manufacture #1
crossy
Pennsville, N.J.
J-D 2305 SCUT, LX279 mower.
what years was the ford 4500 made.?
where do i find the serial number or a data tag of sorts. i saw nothing. that doesn't mean that it wasn't torn off years ago. thanx, crossy
   / 4500 years of manufacture #2
Late 60's through 70's
dang, had that wrong. this thing looks like a 1945. LOL
i figured about 62 though. It has a big hoe on it.
   / 4500 years of manufacture #4
Messick's (New Holland Parts Lookup Online Catalog) says 4500 was manufactured 1/65-12/74.
The 4500 is basically a 4000 and has the numbers as a 4000.
If you are lucky there is still a readable tag on the underside of the hood, above the battery. At FORD CODES and SERIAL NUMBERS you find information on where to find numbers on other places and what they mean.
   / 4500 years of manufacture #5
...manufactured 1/65-12/74.
That's only 10 years of manufacture, not even close to 4500 years.
I like old tractors, but have seen only one model that old.
Bruce
oh-- a guy with MY sense of humor- i like it. thanx , crossy
I cleaned the 1/4" of crud off the underside of hood and found the tag. Tractor #C191151
Model-45011G
Unit-8A5B
Engine-7M4A
Trans-7J13B
Rear Axle-7H11B
Man this hoe is TOO big for this tractor . this thing does wheelies when you hit a bump.
Any jokes about the hoe??? :laughing:
crossy
   / 4500 years of manufacture #9
This may help you out
Tractor model 45011G means:
4..........4000series
50.........inustrial version
1...........diesel
1..........No PTO
G..........Transmission code.
The "G" transmission code doesnt show up on ANYTHING I could find, but Dad has a 4500 TLB with that same trans code. It is a 4F/4R transmission.
There is a flat on the engine casting located just above the starter. It will have that 45011G model number. It will also have the date code where you can use the link I provided to tell exactally when it was made.
And yes, the hoes are quite large and powerful on them machines. As well as the loader. Do you know what model the BH is?? They made a 750, 753, and 755 attachment. They dug to 10ft, 13ft, and 15ft respectivly. ID'ing them is easy, measure the diameter of the main boom and dipperstic cylinders. The 750 had 3.5" cylinders, the 753-4" and the 755-4.5" cylinders.
And if it has the 740 loader on it, them had some massive cylinders as well.
So.....after all that, do you got any pics????
   / 4500 years of manufacture #10
You have all the numbers you need on the tag (VEHICLE IDENTIFICATION PLATE), "UNIT" is the tractor production date code.
Your 4500 was assembled in the USA (Highland Park?) during day shift January 5th 1968.
New/Unused 8 Piece CFG Industrial Mini Excavator Set (A54865)
New/Unused 8 Piece...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2017 Chevrolet Traverse LS SUV (A55853)
2017 Chevrolet...
MULTIQUIP WHISPERWATT MQ POWER 25 GENERATOR (A52706)
MULTIQUIP...
2020 Steiner 450 Slope Mower (A54865)
2020 Steiner 450...
2002 Nissan Xterra 4X4 SUV (A55758)
2002 Nissan Xterra...
