455 deck height adjustment issue
   / 455 deck height adjustment issue #11
No, just no room for the AWS linkage, the rear tires turning, and the FEL frame.
I have the 455 AWS and I really like it. Took me some time to find it, but wouldn't part with it now.
I just picked mine up yesterday. 1999, 530 hrs, 60" deck, 47" snowblower, JD cab. Probably going to add a 3pt hitch so that I can put a ball on and have a place for suitcase weights front and back. Also in case I can put my hands on a hydraulic tiller.
   / 455 deck height adjustment issue #13
Nice find. :)
Suitcase weights don't need the 3 ph, but just a steel plate bolted onto the frame (unless there are other uses for the 3 ph).
   / 455 deck height adjustment issue #14
I have the 3ph on mine and added a 3ph weight bracket. Works very nice for snowblowing, but increases the overall length as well. I welded a receiver tube to the underside of teh bracket and use an inverted 6" ball mount and a convertaball shank only so I can back under trailer/lift/moved/drop without leaving seat. I only do this on relatively level surfaces. Need to lock coupler on ball head if moving far or rough.
For tiller I'd recommend 540 pto driven.
   / 455 deck height adjustment issue #15
If you cut grass at 3 inches or high that deck adjustment needle won't move very much maybe a half inch, mine is set at 3 1/4 inches and the needle just moves about a 1/4 inch
   / 455 deck height adjustment issue #16
Ebay usually has the digital version of the service manuals for sale. Just go to: John Deere 455
Actually, I just downloaded it from GT Talk for FREE:thumbsup: It's a mere 803 pages - guess I won't be printing out a paper copy.
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
2025 JMR 44in Bucket Skid Steer Attachment (A51691)
2025 JMR 44in...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2011 Ford Fusion SE Sedan (A51694)
2011 Ford Fusion...
