4720 and Clearing Cactus
/ 4720 and Clearing Cactus #1
CWP37
Hill Country, TX
John Deere 5103 w/ 512 LDR
Anybody grub cactus with a 4720? What bucket or attachment works best?
I've got about 25 acres to clear and wonder if a skid steer might be a better purchase. Along with a 5203 without the loader.
/ 4720 and Clearing Cactus #2
I assume that you know that any pad left on the ground will grow into another cactus. Thus, you must get it ALL.
How are you planning on proceeding? What kind of ground do you have? Rocky or dirt?
You can get a excellent kill on pear using herbicide.. it just takes a while for it to become obvious that you got it and for it to wilt down into the ground. Several passes a couple of months apart after you can tell which plants are hit and which are still healthy will get you there... 3 years later, it'll all be melted into the ground.
Me, I'd spray unless I needed it physically removed quickly.
Then, I'd do the job with two people, one on a tractor, the other with a long tine pichfork to pick up all the pads and pile them immediately into a flat bed trailer. If in dirt, I'd use FEL to slice just below ground level and get the cactus, roots and all. If in rocky ground, I'd use a toothbar on the FEL.
Herbicide actually works better on plants that have been physically damaged. Thus, you could do the physical removal, then spray the remains, plant by plant.
I've sprayed for cactus, never tried to do wholesale removal physically, except by hand labor and a grubbing hoe... an approach recommended only for the younger generation seeking exercise to lose weight. Best to do this in winter when the rattle snakes are not as active.:eek:
/ 4720 and Clearing Cactus #3
TexasJohn is very correct on leaving any small pieces of cactus, it will start to grow all over again, do NOT mulch it at all and try and get all the roots
Jim
/ 4720 and Clearing Cactus #4
Spray it good.
Then spray it again.
They can be a real pain. Some people doze them up and burn them...
D.
/ 4720 and Clearing Cactus #5
Check out this site. They make a bucket that may just fill your needs.........depending on the soil type you are working in. I sold a ballast box to a guy that was going to use one of these to clear out some cactus in TX. Never heard from him again!
Sincerely, Dirt
Rock bucket, skid steer loader rock buckets with skeleton tines.
/ 4720 and Clearing Cactus #6
If you don't get all the cactus root then it will just come right back also.
I have used the Manuel shovel to remove all my cactus and what still comes up on a regular basis.
Cactus is a pain to remove and 25 acres is bulldozer territory and burn with whatever brush you can put with it.
Rent a bulldozer for a week and make many burn piles.
Whatever you do "DON'T mow it, you will just spread it.
