4720 FEL Bucket Cutting Edge Question
   / 4720 FEL Bucket Cutting Edge Question #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I have a 4720 with the 400x with the lighweight material bucket. I need to break up an old tank berm and use the dirt elsewhere. I am pretty sure I need some teeth on my bucket. A heavy duty JD bucket is $1,000. Should I just bolt some teeth on my bucket or eat the extra $1000 and have another bucket?
Thanks,
D.
   / 4720 FEL Bucket Cutting Edge Question #2
Why not have some 1/2 to 1 inch x 3 inch strips (or bigger) welded across the top edge, along side and across the bottom of the bucket for bracing and then add the tooth bar? If it doesn't work, you aren't out that much money and you could still get a HD bucket later if needed.
   / 4720 FEL Bucket Cutting Edge Question #4
Did you contact Markham welding?
Markhamwelding.com
Their edge is designed for the materials bucket you have (smooth edge). Price is $250ish shipped generally.
   / 4720 FEL Bucket Cutting Edge Question #5
This is the latest pricing on buckets from the JD configurator:
61 In. (1550 mm) Heavy Duty Bucket with Holes for Cutting Edge 9030 $695.00
73 In. (1850 mm) Heavy Duty Bucket with Holes for Cutting Edge 9035 $780.00
   / 4720 FEL Bucket Cutting Edge Question #6
go for the heavier bucket or if you really want a better bucket or get the 4 in 1 bucket. fantastic
   / 4720 FEL Bucket Cutting Edge Question #7
hi there, i just ordered a heavy duty JD tooth bar for my heavy duty 61" bucket for my 3320 from the JD dealer, the msrp was around $350 but the dealer let me have it for $260 total that's without tax. imho i felt that by the time i ordered an aftermarket tooth bar paid shipping etc. it would end up being about the same price + if i ever need a replacement tooth or something i can just go to the dealer and get it instead of waiting for the parts to be shipped. just a thought. well have a good day! larry
1984 Utility 44 ft. Reefer Trailer (A53117)
1984 Utility 44...
15ft. Diamondback Airboat with S/A Aluminum Trailer (A51694)
15ft. Diamondback...
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
HANGCHA CPCD25-XW98C-RT4 STRAIGHT MAST FORKLIFT (A51406)
HANGCHA...
2025 Swict 66in Bucket Skid Steer Attachment (A51691)
2025 Swict 66in...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
