4720 Hydraulic issues
   / 4720 Hydraulic issues
Well guys, here we are a couple of months after I started this thread and I have to say, I believe my controls have loosened up a bit to the point that "feathering" both the boom and bucket controls is a bit easier.
To repeat, what I did over a month ago was pull the rubber boot over the loader control stick and give the cable a heavy dose of WD-40 where it comes out of the plastic "cup". I think that sooner or later that stuff has penetrated the cable.
   / 4720 Hydraulic issues #12
I would doubt you could spray wd 40 under the joystick boot and get it to the cable. At any rate glad it is working better for you now.
To Clarify, I pulled the boot off. This exposes the linkage where the rod connects to the cable. I sprayed the **** out of that connection. I will take a picture. I must admit, I'm not handling same weights I was a couple of months ago when I first started complaining (using forks to off load antique stationary engines from truck bed height) but I have been handling old granite curbing (with forks and with Wildkat 48) and it has been working much smoother.
   / 4720 Hydraulic issues #14
I like to use the Chain and Cable lube from NAPA. Pricey but good, weatherproof somewhat also.
NAPA AUTO PARTS
NAPA AUTO PARTS
Thx- is it light weight? If not it won't penetrate the sheath at the end of the casble-keep in mind you can't really get at the cable-its a pretty tight assembly.
   / 4720 Hydraulic issues #16
If you wan't to try a thin or light lubricant you might try some of the wire lubricant for mig welding wire. About the same weight as lighter fluid.
   / 4720 Hydraulic issues #17
I like Blaster Garage door lube for throttle and choke cables and door hinges. I am not sure if it will work for your application.
Garage Door Lube
Grapple Mini Excavator Attachment (A56857)
Grapple Mini...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
DOOSAN G25 GENERATOR (A58216)
DOOSAN G25...
Bell 1600 Gallon Nurse Trailer (A56436)
Bell 1600 Gallon...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2015 GENIE S-45 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-45...
