4720 Windshield Wiper Failure
/ 4720 Windshield Wiper Failure #1
TCowner
Platinum Member
SE Minnesota
John Deere 4720 Cab
Since I was quick to point out any little problem with the New Holland TC40D and DAs I owned prior to the JD 4720 I fell an obligation to "nip" Deere when they fail as well.
Last week the front winshield wiper failed. The rear wiper continued to work so I knew it was not the fuse as both front and rear are on the same circuit.
The local dealer determined it was a bad motor and replaced it so I'm back in business.
It's been an unusually cool and wet spring in SE Minnesota. The ComfortGard cab has been great and I'm glad I went with the factory cab over the Curtis cab. Hauling brush with the grapple when its 36 degrees and a cold east wind is actually quite enjoyable in the cab.
But I just couldn't let Deere off without a little "dig". Hopefully this is my little electrical gremlin that everyone seems to have with a new tractor.
/ 4720 Windshield Wiper Failure #2
I got a 3520 Deluxe Cab coming and I am a bit leary about the windshield wipers
/ 4720 Windshield Wiper Failure #3
Nuru, what makes you leary on the wipers? I havent used my wiper other then during the delivery (Just to make sure it worked)...Planning on adding a rear wiper no later then this fall...I dont plan on using em in the summer as I can see them scratching the glass more then anything. But come snowblowing season, I'll be needing em.
Only thing thats happened to mine thus far is the speed sensor. No big deal..went to the dealer, service dept knew exactly what it was and had me out the door with a new sensor in 5 mins. I swapped it out this afternoon and all is well once again.
/ 4720 Windshield Wiper Failure #4
The only issue with my 4720 (cabbed) is that it seems awful squeaky when on the move and have not had time to address the issue with the dealer.
Other than that it has fully lived up to all the expectations i have asked of it.
/ 4720 Windshield Wiper Failure #5
I had exactly that "Squeaky" situation anytime I hit a bump or used the FEL...turns out it was the Door & Window Gaskets being "Dry"...lubed up the Jams with some Spray Silicone and she's silent now.
How I found out/tested....Open the doors & window and blip the FEL boom up & down.
/ 4720 Windshield Wiper Failure #6
Spudland_Dave, I was thinking that would be an item that might go bad frequently for some reason - dunno why. Probably just 'noid
/ 4720 Windshield Wiper Failure #7
Gee, thanks Spudland_Dave, i am putting these all in memory!
/ 4720 Windshield Wiper Failure #8
Appreciate the tip, thanks!! Owe you one if it works out!!!
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2018 PETERBILT 567 FLATTOP SLEEPER TRK (A67714)
2018 PETERBILT 567...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A65054)
1994 CHEVROLET...
1062 (A63291)
1062 (A63291)
2014 GENIE  GTH1544 (A67714)
2014 GENIE...
2014 Dodge Grand Caravan Van, (A66738)
2014 Dodge Grand...
