imgone52
Two other major factors to consider - How tight you try to turn and ground speed in the turn. Slow down and make a little wider turn for less tear out.:thumbsup:
I strongly disagree about the 4 wheel drive not playing much of a part. When turning sharply with any tires the front to rear differential difference causes the tire with least resistance to spin, in turn it chews up the grass.
If 4 wheel drive is not engaged the tires do not spin, therefore not near the damage.
I'm sure you are correct about the rib tires and I am not disagreeing with that.
I'm probably wrong but won't be the first time.![]()
So, are you able to turn 4WD on/off as needed on Yanmars?
Yea there is a lever to put in in 4wd
