4x4 Question
   / 4x4 Question #221
N80 said:
Actually, the 4wd L4400 has a tighter turning radius than the 2wd L4400 by nearly a foot according to specs. But, that is based on one rear wheel being locked.
I'd be willing to bet you two of my previous post against a hole in a donut it's a misprint ;)
   / 4x4 Question #222
Not sure why the manual would even post that scenario, it's talking about having the inside rear wheel locked using the brake. I would hope no one would do that with the MFWD engaged. But ya never know!!! :)
   / 4x4 Question #223
N80 said:
My Kubota manual calls it 4wd. There is a sticker on the fender from the factory that says "4WD".
My Ford pickup has a "4WD" sticker on it from the factory.
We all know how the systems work, but if you have a problem with what Kubota _calls_ its system, you'll have to give Mr. Kubota a call and set him straight.
Besides, can you hear one of us, talking to our buds or farmer friends, saying "Well , ah, technically speaking your tractor is not a 4 wheel drive, it is a 3 wheel drive, when the rear diff is locked, of course, and really just a two wheel drive when it isn't....technically speaking of course." Do that and you're likely to get a pocket protector for Christmas and season one of Erkle on video tape.
Hmmmm, so are you saying your L4400 will always spin all 4 wheels when the MFWD is engaged??? Hmmmmm.
   / 4x4 Question #224
Dargo said:
I've operated several tractors that had a locking front differential as well as the standard locking rear differential. They would have to be considered 4wd. They pull really well that way, but sure won't turn worth a darn! ;)
Good Post!!! That's what I was referring to, just didn't know if they existed. My Jeeps have front diff locks as well as rear. You are right, they do not want to turn at all!!! Similar to engaging the rear diff on your CUT and trying to turn. If you have a front diff lock on your tractor, then you can honestly say your tractor is 4WD. Otherwise the best you can claim is 3WD. And to N80, all the farmers around my area know that and would have a good time with anyone that claimed because their manual says 4WD, their tractor is 4WD. :)
   / 4x4 Question #225
Nope. Read it again. I'm saying Kubota calls it a "4WD" and if that seems technically inaccurate to you then you'll have to take it up with Kubota.....and JD and NH and all the other tractor manufacturers that use the term "4WD" either exclusively or interchangeably with MFWD. Good luck.
And if you're going to engage in proprietary semantics, no one said "4WD" means that all four wheels spin at the same time. It means that power can be applied through all four wheels. That's not so hard to understand is it?
   / 4x4 Question #226
There is a big difference in marketing buzzwords, and engineering techspeak. I think the 4wd/mfwd, etc vs 3wd(rear difflock ).. etc is coming from.
A tractor would never sell if the marketing put it out as a 3wd machine.. Even though, the power will usually only be transmitted by 3 wheels at a time... 2 rear, and the front with the least resistance.. or in cases where equal front resistance exists..
Soundguy
Soundguy
   / 4x4 Question #227
Really? So lets say you stop by your farmer friend's barn and he tells you he's waiting on delivery of a new Ag tractor. You ask him which one and he says its a new Kubota.
You're interested of course and would like to know if it has a front driveline. Do you ask:
A) Is it a four wheel drive?
b) Is it a three wheel drive when you use the diff lock?
c) Is it a mechanical front wheel drive?
Around here, you'd simply say "It's a four wheel drive" and everyone would know _exactly_ what you were talking about regardless of who made the tractor.
If you told them it was a three wheel drive they'd either think you were being a smart *****, joking or just a dweeb.
If you told them it was "mechanical front wheel drive" they'd simply think you were being overly precise and/or a dweeb.
If it is really that different in Missouri is must be a pleasure to be surrounded by such technically and semantically precise farmers. But we grow them a little different down here.
   / 4x4 Question #228
Hey,,,, I'm just trying to not get muddy!!!!
   / 4x4 Question #229
Do we really have to beat every last word out of this 'semantics' topic?
I thinks it's pretty safe to say that '4wd' is a -generic- term, and MFWD is a specific manufacturers term, and the the 3wd issue is a technical aspect of the functioning of the most common '4wd' systems.
I don't think anyone here is debating those facts... right?
Soundguy
   / 4x4 Question #230
Soundguy
I think you are correct on all counts.
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
2012 JOHN DEERE 644K WHEEL LOADER (A52705)
2012 JOHN DEERE...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2011 New Holland Boomer 90 MFWD Utility Tractor (A53473)
2011 New Holland...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53473)
Ditch Witch 6510A...
