4x4 Question
   / 4x4 Question #1
dtd24
Schenectady, NY
98 JD 1070
I use my tractor w/ the 4x4 engaged most of the time. Have lots of clay and Hilly areas. Should I start to play with 2wd at all?
   / 4x4 Question #2
I don't think running in 4wd most of the time hurts anything. I do know my front and rear axles have a different ratio and I've read it's not best to run on pavement all the time in 4wd. If you need it in the dirt though, you got it. I run in 2wd most of the time, but I know this winter I'll use 4wd a lot.
   / 4x4 Question #3
It's probably best to leave it in 4 wheel drive. I wouldn't want to take a chance of breaking traction. If it does, you may take a ride you don't want to. A lot also depends on what tires you have and the conditions of the ground. Grass covered,dirt,wet,dry,snow,dew,ect....... all play a factor in traction. I have an JD 870 with R1's that I run in 2 wheel drive every once in awhile. I also have a JD 3520 with R4's that I immediately put in 4 wheel drive as soon as I leave my level yard. I think the R4's break traction very easily. Good luck and be safe. If you think you should be in 4 wheel drive, you probably should be.
   / 4x4 Question #4
dtd24:
I run my 4wd tractors in 2wd on pavement; 4wd on anything else. Jay
   / 4x4 Question #5
I guess it gets down to your ground conditions. I rarely put mine in 4wd. Only when doing lots of digging loader work.
   / 4x4 Question #6
I use the front wheel assist as required. That's probably about 50% of the time.
The only way you'll know is by trying the task in 2WD. If your rear wheels spin, it's time for the differential lock or front wheel assist.
   / 4x4 Question #7
I recently had a wise farmer tell me that you should use 2wd until you can't go anymore and then use 4wd to get home...I tend to agree, unless I am doing FEL work. I use 2wd to tell me when I am getting close to being over my head..including when lifting something with the FEL or running on a side hill...if the uphill back tire is losing traction b/c it is so light, it is time to reassess the situation. if I ran in 4wd all the time, i wouldn't have this safety net.
W
   / 4x4 Question #8
I only use 4wd for loader work or because I have to (stuck, slick conditions, etc). I have found when I mow in 4wd that I tend to leave tire marks on the lawn when I turn. But, I have grey market with those rice tires. Probably in turfs nothing would happen. I also don't have any big slopes.
   / 4x4 Question #9
I use 4wd just like I do on my truck, when I need it. Then it goes back to 2wd.
   / 4x4 Question #10
I use 4WD when I use the loader and also when pulling my box scraper. These are two areas where you can definitely get the rears to spin in 2WD.
2011 CATERPILLAR 259B3 SKID STEER (A51242)
2011 CATERPILLAR...
2018 HINO 258 S/A SERVICE TRUCK (A51243)
2018 HINO 258 S/A...
KUBOTA M6800 TRACTOR (A51243)
KUBOTA M6800...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2008 CATERPILLAR 430E BACKHOE (A51242)
2008 CATERPILLAR...
